HKS Focus
9 Attachment(s)
Arias Pistons – 9.5:1
Eagle Rods ARP main studs and head bolts Ported/polished head, crower springs, retainers Crower stage 2 cams – old style Ford Racing intake manifold with custom fabricated adapter to mate to head. Focus Central 65mm throttle body 1000cc injectors HKS F-CON VPRO Fuel management computer Twin Bosch “004” high flow fuel pumps 5 Gal fuel cell HKS Custom Modified fuel rail Custom stainless turbo manifold HKS GT-II 50mm Wastegate HKS GT3037S Turbocharger Custom fab exhaust by HKS HKS Type S Intercooler Custom fab breather box Custom fab coolant recovery system HKS EVC PRO Boost Controller DPG Billet Clutch and flywheel with solid hub sintered iron disc Quaife differential Autopower Roll bar KW coilovers 600hp/447 on wheels @17.5 psi 11.3@142 mph |
ffocus, cand te vedem si pe tine cu focus din asta?! :wink: Masina arata demential! Acuma iau filmuletul sa vad care-i treaba cu el! :wink:
e foarte misto masina, sau mai bine zis ce a iesit.....
marfa rau de tot, as vrea sa vad pe viu asa ceva |
sa mor io ce sunet are masina aia!
sper k o sa fie ceva de genu asta si pe 22 pe aeroportu din oradea... |
Serpisorii aia mi s-ar potrivi PERFECT :D
| All times are GMT +2. The time now is 10:29. |
