Noul EVO 9 ..pareri si impresii
noul EVO 9 ..pareri si impresii
March 24, 2005 -- NEW YORK -- Loaded with power and aerodynamic enhancements culled from Mitsubishi's rally-racing success during the past 13 years, the Lancer IX was introduced today at the New York International Automobile Show. It is the 12th model in a series of Mitsubishi Motors' award-winning sedans and was originally introduced to satisfy FIA Group A rally specifications that called for a production model. Evolution The 2006 Lancer features a standard two-liter DOHC 16-valve I-4 intercooled turbocharged engine, which is enhanced this year with variable valve technology (VVT). This Mitsubishi Innovative Valve timing and lift Electronic Control (MIVEC) system utilizes a VVT sprocket to optimize valve timing relative to the engine condition. This technological advancement, combined with enhancements to the vehicle's turbocharger, produces higher torque and better response for improved engine performance across the complete rpm range. New gear ratios on the models' standard five-speed manual transmission take full advantage of the increased power. True to its racing heritage, the Lancer Evolution IX also features a number of exterior enhancements to further improve the aerodynamics and cooling performance of the vehicle. A new front fascia houses an oversize mesh grille and front center bumper air inlets to improve engine-cooling efficiency. Complementing the exterior enhancements, Mitsubishi Motors engineers also updated the Lancer Evolution IX interior. The driver is strapped in front of a new dark three-spoke, height-adjustable Momo steering wheel and carbon fiber-style instrument, center and shift panels. Standard Recaro bucket seats feature Alcantara upholstery. The Lancer Evolution IX is available in stock trim, as well as RS and an MR edition featuring a six-speed close-ratio manual transmission and Bilstein monotube shock absorbers. Owners can further customize their vehicles to meet individual tastes through a comprehensive range of factory- and dealer-installed options including new air dam extensions and rear-wing wicker bills. Story by Mitsubishi Motors North America engine Cast Iron Inline-4 position Front, Transverse aspiration Twin Scroll Turbocharger w/Intercooler valvetrain DOHC, 4 Valves per Cyl w/MIVEC VVT fuel feed Electronic Fuel Injection displacement 1997 cc / 121.9 cu in bore 85.09 mm / 3.35 in stroke 87.88 mm / 3.46 in power 213.3 kw / 286 bhp @ 6500 rpm hp per litre 143.21 bhp per litre bhp/weight 191.95 bhp per weight torque 391.83 nm / 289 ft lbs @ 3500 rpm redline 7000 drive wheels Full Time 4WD w/active Center Differential, Front Limited Slip, Rear Mechincal Limited Slip body / frame Unit Steel front brakes Brembro Discs w/4-Piston Calipers, ABS, EBD f brake size 320 mm / 12.6 in rear brakes Brembro Discs w/Twin-Piston Calipers, ABS, EBD r brake size 305 mm / 12 in front wheels F 43.2 x 20.3 cm / 17 x 8 in rear wheels R 43.2 x 20.3 cm / 17 x 8 in front tire size P235/45R17 rear tire size P235/45R17 steering Rack & Pinion w/Power Assist f suspension MacPherson Struts w/Bilstein Shock Absorbers, Trailing Links, Lateral Links, Stabilizer Bar r suspension Mulit-Link w/Bilstein Shock Absorbers, Trailing Links, Lateral Links, Stabilizer Bar weight 1490 kg / 3285 lbs wheelbase 2625 mm / 103.3 in front track 1515 mm / 59.6 in rear track 1515 mm / 59.6 in length 4535 mm / 178.5 in width 1770 mm / 69.7 in height 1450 mm / 57.1 in transmission 6-Speed Manual gear ratios 2.909:1, 1.944:1, 1.434:1, 1.100:1, 0.868:1, 0.693:1 final drive 4.538:1 |
punt totul pe EVO 9 . Nush daca are performantele mai bune decat STI si chiar daca nu are e mult mai tare la design si la confort interior.
STI are interior de tractor UNIVERSAL 650. |
Imi place nimic de zis, dar jentile sunt prea asemanatoare cu cele de pe STi. voua nu vi se pare? :roll:
super faina masina pt mine ii clar mult mai tare de cat sti nu stiu de ce dar nu sunt fan subaru deloc oare de ce? :lol:
:shock: e mishto :)
la prima vedere seamana super bine cu evo 8 ;) dar daca te uiti mai atent :) nu e chear asha e mishto rau:D |
Eu sunt mare fan STi :), imi place si Evo dar dragostea vietii mele ramane tot STi :).EVO este mai manevrabil dar STi are motorul mai bun.Nu prea ma intereseaza ca STi are un interior mai spartan.
Re:
Evo 9 e fain , astept sa vad cum o sa arate si Subaru :twisted: |
Evo rullz... :lol: cel putin in ceea ce priveste designul atat int. cat si ext. EVO este mai reusit decat STI.. 8)
No comment 8)
grava rau....si pretul?
In jur de 40,000 $ cip (cred)
EVO
Imi permit sa mai adaug nishte poze ca sa-mi subliniez optiunea pt EVO 9
Pret : intre 55 000 - 70 000 E (DDP - toate taxele) depinzand si de echipare ca vor scoate 3 variante |
rupe EVOu asta nou!
Sti are motor mai bengos da evou ii mai manevrabil si arata mult mai bine. evou pare mai elegant si in acelasi timp mai agresiv decat Sti |
:roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
ce rupe??? Sunt fan EVO de cand pilota Makkinen unul prin 96(sper sa nu greesc anul)! Deci am votat EVO... |
| All times are GMT +2. The time now is 13:43. |
