-   Hardware (https://forum.4tuning.ro/509-hardware.html)
-   -   PC-ul meu :) Sistemul de racire pe apa e custom made de mine (https://forum.4tuning.ro/509-hardware/451436-pc-meu-sistemul-racire-apa-custom-made-mine.html)
TurboRacer1990 27-06-19 12:05
Asta e sistemul facut de mine, sper sa pot juca Cyberpunk 2077 cand apare pe el!
https://megagames.com/sites/default/.../image_12.jpeg
https://megagames.com/sites/default/.../image_11.jpeg
https://megagames.com/sites/default/.../image_29.jpeg
https://megagames.com/sites/default/.../image_22.jpeg
Specificatii sistem:
- GPU: Gainward GeForce GTX 960 Phantom, 2GB GDDR5, 128-bit (DirectX 12)
- CPU: AMD FX-8350 BLACK EDITION - 8 Cores, 4 GHz, AM3+
- RAM: 20 GB Kingston HyperX Blue: - 2 x 8 GB + 4 GB - DDR 3, 1600 MHz, CL 10, 1,5 V
- PSU: Corsair V550 - 550 W
- Motherboard: Gigabyte GA-78LMT-S2PV
- HDD: 320 GB Western Digital HDD
- Case: Thermaltake VIEW 27
- Cooling: Modified ID-Cooling ICEKIMO 120B Closed Loop Water Cooling (black rubber tubing replaced with clear PVC tubing and RGB LED coolant tank added) + Thermaltake 120 mm black fan + Deep Cool 80 mm blue LED clear fan + 3 x Segotep 120 mm blue LED clear fans
- "Peltier Reactor" - experimental custom cooling module, made from a DIY water tank with 5 Peltier / TEC units and 5 Delta fans and digital thermometer attached, for extreme cooling (theoretically up to -50 degrees Celsius!)
- OS: Windows 7 (64-bit) Ultimate Edition
- Monitor: SAMSUNG 1080P, Full HD, 80 CM wide TV, connected to PC via HDMI
- Keyboard: Green LED backlit keys Gaming Keyboard
- Mouse: COBRA Gaming Mouse, blue LED lit + COBRA mousepad
- Controller: Wireless XBox 360 Controller + wireless PC adapter
