statie, subwoofer, boxe
DLS RMS output per channel at 13,8 volts
Mode : AB Number of channels : 2 Nominal power output in 4 ohm (0,1% THD) : 2 x 100 W Typical power output in 4 ohm (0,1% THD) : 2 x 135 W Typical power output in 2 ohm (0,2% THD) : 2 x 200 W Typical power output in 4 ohm bridge mode : 400 W Frequency range : 10 Hz - 35 kHz S / N-ratio, A-weighted : > 100 dB Damping factor : > 100 Input impedance low level : > 10 kohm Input impedance, high level : 100 ohm Input sensitivity, variable : 0,25 - 5 V High level input with auto start : Ja Low level output : Ja Highpass filter / subsonic variable : 15 - 150 Hz Lowpass filter variable : 50 - 500 Hz Grand bass adjustable frequency : 25 - 80 Hz Grand bass adjustable level : 0-18 dB Current draw, idle : 0,7 A Fuse value : 2 x 30 A Dimensions H x D x B : 67 x 295 x 250 mm (2,63 x 11,6 x 9,84 inch) Weight : 3,6 kg ( 7,9 lb) Pret : 6.000.000 lei MAC AUDIO Z2100 Number of channels : 2 Max. power output into 4 ohm - Kanäle 1-2: 2 x150 W / 1 x 500 W RMS power output into 4 ohms - Kanäle 1-2: 2 x 70 W / 1 x 200 W Max. power output into 2 ohms - Kanäle 1-2: 2 x 200 W RMS power output into 2 ohms - Kanäle 1-2: 2 x 100 W Dimensions H x D x B : 265 x 54 x 293 mm Pret : 4.500.000 lei MAC AUDIO 4051 Max. power output into 4 ohm - Kanäle 1-4: 4 x130 W / 2 x 450 W RMS power output into 4 ohms - Kanäle 1-4: 4 x 60 W / 2 x 160 W Max. power output into 2 ohms - Kanäle 1-4: 4 x 200 W RMS power output into 2 ohms - Kanäle 1-4: 2 x 80 W Pret : 6.000.000 lei MAC AUDIO RED TUBE passive 12\" bassreflex tube subwoofer Nominal Power handling: 240 Watt Max. Power handling: 480 Watt Impedance: 4 Ohm lower cut-off frequency: 20 Hz upper cut-off frequency: 1000 Hz soundpressure level: 93 dB measurements: 335 x 550 x 335 mm Pret : 3.000.000 lei Mac Premium Reflex 300 passive 12\" bassreflex subwoofer Nominal Power handling: 250 Watt Max. Power handling: 500 Watt Impedance: 4 Ohm lower cut-off frequency: 20 Hz upper cut-off frequency: 500 Hz soundpressure level: 93 dB measurements: 540 x 340 x 340 mm specials: LED blue illuminated cone Massive 19 mm cabinet Screw terminal High quality non-slip carpet Protection bars Pret : 4.800.000 lei Mac Ice Cube 225 Nominal Power handling: 250 Watt Max. Power handling: 500 Watt Impedance: 4 Ohm lower cut-off frequency: 18 Hz upper cut-off frequency: 250 Hz soundpressure level: 93 dB measurements: 630 x 345 x 430 mm Pret : 10.000.000 lei 0723.360.568 |
eu am pe masina macaudio 4051 si mx reflex 30 . e mai mult decat suficient, iar ca \"bani\" fac fiecare leu.
| All times are GMT +2. The time now is 12:41. |
