-   PC Games (https://forum.4tuning.ro/510-pc-games.html)
-   -   Need For Speed cars (https://forum.4tuning.ro/510-pc-games/44124-need-for-speed-cars.html)
Opportunity 19-06-07 20:31
Need For Speed cars
Propun sa se uneasca toate topicurile aici pentru a face un update al masinilor.. voi face eu o lista
Dacia 1300 ( NFS MW)
http://www.nfscars.net/file/image.aspx?id=6775
Dacia Logan (NFS MW)
http://www.nfscars.net/file/image.aspx?id=6679
Si daca ma ajutati cu linkuri o sa editez postul ( daca mai pot dupa un anumit interval de timp.. )
Un tutorial (merita citit pentru a instala masinile in most wanted)
Before we begin, make sure you have these REQUIREMENTS:
-NFSMW Game
-Total Commander or Windows Explorer
-A little knowledge and understanding
-Download Manager to Download Cars.
-Patched NFSMW to V1.3
REMEMBER TO PATCH YOUR NFSMW TO V1.3 OR IT WILL NOT WORK.
Let's begin, shall we?
Step 1 - Getting the 360 Spider & Mod Loader
The first thing you need to do and required all the time, DOWNLOAD THE FERRARI 360 SPIDER. The 360 Spider has the mod loader which allows you to load the car logos and the cars. Download the 360 Spider and save it to anywhere.
Recommended Place to Save: Desktop
Step 1 Reference Links:
360 Spider Link: http://www.nfscars.net/file/view/mostwanted/6464.aspx
When you are done, move on to Step 2.
Step 2 - Download the modded car you wish to put in NFSMW
You got the 360 Spider, that's checked. Now, DOWNLOAD THE CAR YOU WISH TO PLACE IN THE GAME. If you want to download the BMW M6 and put in game, for example, click on the BMW M6 link(scroll below to see), download it using the West Coast server. (Do not use East Coast as the server will give you damaged zip file of M6 with the wrong size of file)
For this tutorial, I will be using the Bugatti Veyron 16/4 Mod Installation for the tutorial
(Original model made by DMi and converted by Finalmaster2 to NFSMW.)
Step 2 Reference Links:
SCROLL DOWN TO LOOK FOR CARS FOR MW.
Moving on to Step 3 .
Step 3 - Extracting the files from the downloaded 360 Spider ZIP file.
You got the 360 Spider, you also got the modded car you wanted in game. Here is where it gets a bit difficult, FOLLOW THE INSTRUCTIONS CAREFULLY.
Firstly, create a Temporarily folder anywhere. I recommend you to create a Temporarily folder on the desktop. This is where you use the total commander and navigate one side of the window to the location "Desktop". Name this folder as "Car Temp 1".
Now, on the other side of the Total Commander window, go to the same location but this time, your cursor must point to the downloaded 360 Spider zip file. Check that the other side of the Total Commander must be at the folder "Car Temp 1". Press ALT + F9 when you are using the cursor and pointing at the 360 Spider zip file and it will unpack the files to the folder.
When it's unzipped done, press Tab button on your keyboard and it will switch the sides, from the right to left. Now in the folder, Launch the install.exe. This will install the 360 Spider & Modloader. (Read the readme FIRST Before you install the Ferrari 360 Spider if you don't agree to installing IT.)
There's 2 part choices here, Full Installation OR Half Installation.
Step 3 Part 1 - Full Installation (Modloader + 360 Spider)
If you install and you want the 360 Spider, just click next and wait until the installation ends.
Step 3 Part 2 - Half Installation (Modloader ONLY)
If you install and you want ONLY the Mod Loader, there's an option for you to tick whether you want 360 Spider or not. Untick the 360 Spider box and click next. Then it will install only the mod loader.
We are done, let's go to Step 4!
Step 4 - Extracting the downloaded car zip file.
You got the 360 Spider & Modloader installed, or only Modloader. Now you are ready to get your downloaded car into NFSMW! Just a few more steps and your done.
Go back to your total commander. Again, use the left side of the Total Commander and go back to the Desktop. Press F7 which will create a new folder. Name the new folder as "Car Temp 2". Go into the folder and leave it there.
Press Tab button on your keyboard and it will switch to the right side. Move your cursor over to the downloaded car, for example, I downloaded the Veyron and saved the file name as veyron164.zip (OR whatever you saved it as). Hover your cursor to your downloaded car and press ALT + F9 again. And it will unzip the files to the "Car Temp 2" folder.
If your done, you left 1 more step to go. Go on to Step 5.
Step 5 - Copying the unzipped downloaded car files to the NFSMW folder & Updating your Mod Loader to update the car logos.
Your a few minutes away from getting the new car in NFSMW. LISTEN TO THESE STEPS CAREFULLY AT THIS PART AS IT IS GOING TO GET HARDER. IF YOU DO NOT UNDERSTAND, READ AGAIN UNTIL YOU UNDERSTAND. IF YOU STILL DO NOT GET IT, DO NOT TRY IT ON YOUR OWN OR YOU WILL MESS YOUR GAME UP.
On your right side of the Total Commander, Locate your NFSMW folder and go inside it. You will see alot of folders and files. Now, in your NFSMW Game Folder, Press F7 if your on Total Commander and it will create a new folder. Name the new folder as ADDONS (Notice the caps? Type all in caps, not small letters. :-))
Go into the folder ADDONS. Inside there, create a new folder again pressing the F7 if your using Total Commander. Name the new folder as CARS_REPLACE (Type it as the same, cannot me Cars_Replace or CARS_Replace or whatever it is, only CARS_REPLACE)
Go into the folder CARS_REPLACE and stay there. Now press Tab (in Total Commander) to switch sides. You switched to the folder you last created, which is named "Car Temp 2".
Now in the "Car Temp 2" folder, you should see a folder called "CARS_REPLACE". Go into the folder. you see a folder of the car name. If it's GTO, it will replace the Pontiac GTO in the game.
READ HERE CAREFULLY.
Copy the folder named "GTO" or whatever it has in the CARS_REPLACE folder to C:/Program Files/Need For Speed Most Wanted/ADDONS/CARS_REPLACE/ folder or wherever your game in installed.
EXTRA NOTE ADDED: If there is another folder when you unzipped from the ZIP file, copy it to your NFSMW Game/ADDONS/ Folder.
When you copy finish, go back to your modloader and update your mod loader. When you updated, the car logos and car will be updated.
Testing the Car
You got everything done. Now to test if your car works, do these.
-Launch your NFSMW Game.
-Load your profile.
-Go to Quick Race
-Select Custom Race, any race type and the settings.
-When it asks to choose the car, select the car it has replaced. Best results to see is the "Stock" section. If it replaces the Pontiac GTO, navigate to Pontiac GTO. If it replace C6R or 911 GT2, it is in the "Bonus" section of your cars.
Well, that's it. You got a modded car in game. Remember, if you want to add more cars, repeat Step 4 & 5 only. Step 1 & 3 is not needed to repeat as you already have the Mod Loader & 360 Spider.
Have fun NFS Racing guys!
I hope this tutorial have helped the beginners who don't know how to add modded cars in MW.
Craxy 19-06-07 21:56
Re: Need For Speed cars
mai exista o discutie pe tema asta...:rolleyes2 oricum daca vrei masini ia de pe nfscars.net
Opportunity 19-06-07 22:03
am incercat sa fiu de ajutor cu masini si cu tutorial..
Tahity 21-06-07 21:56
mah eu vreau un trabant in nfs ... este :D :D ... no ofence
sau un lamborghini
Opportunity 21-06-07 22:03
Domne, nu te supara..
1. nu mai spamma topicurile pentru posturi multe
2. ai butonul cu functia EDIT ca sa nu mai faci 2 posturi
Si ca sa iti raspund la intrebare: in MW este deja lamborghini..
AdiNX 21-06-07 22:45
greseala lui tahity a fost rectificata :)
bogdan C.E.T. 23-06-07 11:58
7 Attachment(s)
MW ... cateva masini
1153320512.zip - de asta aveti nevoie prima oara , ca sa bagati si alte masini . masinile se baga in folderu unde aveti most wanted , apoi ADDONS , dupa CARS_REPLACE. jocul il porniti de pe desktop ,unde o sa fie un folder :Need for Speed™ Most Wanted (Mod Loader)
1154925679-S2000-Coupe.zip - Honda S2000
1157202435-M6.zip - BMW M6
1158165653-Veyron-16.4-2004.zip - Bugatti Veyron
1155393522-F1-LM.zip - mclaren f1
Ca sa mearga masinile trebuie sa aveti patchul 1.3 altfel nu merg.
