Techart CARRERA GT VS Gemballa MIRAGE GT
9 Attachment(s)
poate cele mai frumoase masini din lume........
Re: Techart CARRERA GT VS Gemballa MIRAGE GT
inca ceva poze....
Techart-engine Aluminum, 68 Degree, Water Cooled V10 w/Dry Sump Lubrication
position Mid Longitudinal aspiration Natural valvetrain DOHC 4 Valves per Cyl w/VarioCam fuel feed Sequential Multi-Point Fuel Injection displacement 5733 cc / 349.8 cu in bore 98 mm / 3.86 in stroke 76 mm / 2.99 in compression 12.0:1 power 473.5 kw / 635 bhp @ 8000 rpm hp per litre 106.75 bhp per litre bhp/weight 443.48 bhp per weight torque 589.78 nm / 435 ft lbs @ 5750 rpm redline 8400 drive wheels RWD w/ASR 5.7, LSD body / frame Carbon Fibre Body over Carbon Fiber Reinforced Plasitc Frame front brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS f brake size 380 mm / 15.0 in rear brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS r brake size 380 mm / 15.0 in front wheels F 48.3 x 24.1 cm / 19 x 9.5 in rear wheels R 50.8 x 31.8 cm / 20 x 12.5 in front tire size 265/35ZR19 Michelin Pilot Sport 2 rear tire size 335/30ZR20 Michelin Pilot Sport 2 steering Rack & Pinion w/Power Steering f suspension Double Wishbones w/Inboard Springs & Dampers r suspension Double Wishbones w/Inboard Springs & Dampers weight 1380 kg / 3042 lbs wheelbase 2730 mm / 107.5 in front track 1612 mm / 63.5 in rear track 1587 mm / 62.5 in length 4613 mm / 181.6 in width 1920 mm / 75.6 in height 1166 mm / 45.9 in transmission 6-Speed Manual w/Two-Plate Ceramic Dry Clutch gear ratios 3.20:1, 1.87:1, 1.36:1, 1.07:1, 0.90:1, 0.75:1 final drive 4.44:1 top speed 329.9 kph / 205.0 mph 0 - 60 mph 3.8 seconds 0 - 100 mph 6.9 seconds 0 - 1/4 mile 11.4 seconds |
Gemballa-engine Modified V10 w/Low Compression Pistons
position Mid Longitudinal aspiration Twin Turbochargers valvetrain DOHC 4 Valves per Cyl fuel feed Sequential Multi-Point Fuel Injection displacement 5733 cc / 349.8 cu in bore 98 mm / 3.86 in stroke 76 mm / 2.99 in power 484.7 kw / 650 bhp @ 8000 rpm hp per litre 113.38 bhp per litre bhp/weight 471.01 bhp per tonne drive wheels RWD w/ASR 5.7, LSD body / frame Carbon Fibre Body over Carbon Fiber Reinforced Plasitc Frame front brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS f brake size 400 mm / 15.7 in rear brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS r brake size 400 mm / 15.7 in front wheels F 48.3 x 24.1 cm / 19 x 9.5 in rear wheels R 48.3 x 31.8 cm / 19 x 12.5 in front tire size 265/35ZR19 rear tire size 335/30ZR20 steering Rack & Pinion w/Power Steering f suspension Double Wishbones w/Inboard Springs & Dampers r suspension Double Wishbones w/Inboard Springs & Dampers weight 1380 kg / 3042 lbs front track 1612 mm / 63.5 in rear track 1587 mm / 62.5 in length 4613 mm / 181.6 in width 1921 mm / 75.6 in height 1166 mm / 45.9 in transmission 6-Speed Race-Sourced Transaxle gear ratios Not Available36:1 top speed 330 kph / 205.1 mph 0 - 60 mph 3.8 seconds |
bun topic . Motoare cu modificari aproximativ identice..insa designul gemballa intrece orice inchipuire.. :|.. ''mi-as vinde casa , as cumpara o chestie din asta si as trai intr-un tunel'' :))
gemballa mirage gt negru auriu :lol:
Din datele pe care le-ai pus Techartul e superior din punct de vedere tehnologic.Ma refer la motorul aspirat cu came variabile care scoate aproape acelasi numar de cai ca si Gemballa care are si pistoane de compresie scazuta si doua turbine din care scoate doar cu 15 cai mai mult. Ar fi interesant de vazut cu cat e mai mare cuplul la Gemballa si cat de mare e diferenta pe 400m. Ceva imi spune ca nu e mare diferenta la timpi, iar timpii egali de 0-100km/h confirma chestia asta.
In mod sigur as alege Techartul, motivul real pt care Gemballa cu 2 turbine nu scoate simtitor mai multa putere probabil fiind unul economic (costurile de productie deveneau prea ridicate???) sau poate de marketing... De mentionat ca prezenta turbinelor si a pistoanelor de compresie joasa preteaza Gemballa la tuning (daca cineva ar fi destul de nebun sa mai faca ceva la masina aia :lol: ) |
Gemballa Mirage GT- Se presupune ca ar fi produsa acum si o varianta de 1000 de cai putere si 1150 Nm , deja unul dintre aceste modele apartinand afaceristului arab Ilyas Galadari.Momentan aceasta dezvoltand doar 700 din cei 1000 de cai promisi insa lucrarile la motor nu au fost finalizate masina urmand sa fie trimisa innapoi pentru finisare.(Din spusele fiului sau pe un forum....asa ca...) iar acceleratia de la 0 la 100 fiind situat in jurul valorii de 3.5 secunde cea ce imi pare stupid. De la o la 200 in 8 si o viteza maxima de 403.Din cate se pare aceste surse nu sunt exacte asa ca daca stiti altceva postati datele referitoare la ea.Tare as vrea sa vad ce poate o masina de o forta bruta asemanatoare veyronului dar cu aproximativ 800-900 de kilograme mai putin.
porche-u......::D
oricare dintre ele va fi la fel de inutila in centru bucurestiului la ora 6 dupamasa
| All times are GMT +2. The time now is 08:41. |
