VAND: Difuzor Subwoofer JL Audio 6.5" 16.5cm 150w
Folosit doar 2 zile, practic nou. Din pacate nu am amplificator capabil pentru el.
0722340642 General Specifications Table_Image Continuous Power Handling (RMS) 150 W Recommended RMS Amplifier Power 50 - 150 W Nominal Impedance (Znom) 4 Ω Physical Specifications Table_Image Nominal Diameter 6.5 in / 165 mm Overall Diameter (A) 6.85 in / 174 mm Mounting Hole Diameter (B) 5.5 in / 140 mm Bolt Hole Circle (C) 6.125 in / 156 mm Magnet Diameter (D) 4.25 in / 108 mm Mounting Depth (E) 4.25 in / 108 mm Driver Displacement 0.02 cu ft / 0.57 L Net Weight 6.1 lb / 2.8 kg Parameters Free Air Resonance (Fs) 41.80 Hz Electrical “Q” (Qes) 0.533 Mechanical “Q” (Qms) 11.027 Total Speaker “Q” (Qts) 0.508 Equivalent Compliance (Vas) 0.181 cu ft / 5.13 L One-Way Linear Excursion (Xmax)* 0.35 in / 8.89 mm Reference Efficiency (no) 0.0700% Efficiency (1 W / 1 m)** 80.49 dB SPL Effective Piston Area (Sd) 17.36 sq in / 0.0112 sq m DC Resistance (Re) 3.476 Ω * Xmax specifications are derived via one-way voice coil overhang method with no correction factors applied. ** Efficiency (1 W / 1 m) is not an accurate indicator of a subwoofer′s output capability and should not be used as a comparison to other subwoofers to determine which one is “louder”. Sealed Enclosure Specifications Table_Image Wall Thickness 0.5 in / 13 mm Front Baffle Thickness 0.5 in / 13 mm Volume (net int.) 0.15 cu ft / 4.2 L External Width (W) 8.5 in / 216 mm External Height (H) 8.5 in / 216 mm External Depth (D) 6.25 in / 159 mm F3 34 Hz Fc 60.6 Hz Qtc 0.729 Tip produs Subwoofer Pasiv Tip Incinta Incinta Deschisa Diametru Difuzor 16.5 cm |
Re: VAND: Difuzor Subwoofer JL Audio 6.5" 16.5cm 150w
599 lei pret, srry !
model 6W3v3-4
Salut.
Mai ai difuzorul? Ultimul pret? Multumesc. |
