Midbasi DLS UP6
Vand o pereche de midbasi DLS Ultimate dintr-un set pe 2 cai descomplectat UP6
Outer diameter 165 mm Magnet diameter 62 mm Magnet material Neodymium Mounting depth 63 mm Mounting hole 140 mm Nominal power handling 150 W RMS Transient power, 10 ms 180 W Nominal impedance, Z 4 ohms Sensitivity, 1 W / 1m 89 dB Frequency response 55-3500 Hz Fs, resonant frequency 64,8 Hz Voice coil diameter 54 mm (2”) Voice coil height 13 mm Voice coil type / former Aluminium Voice coil wire Aluminium flat wire Number of layers 2 DC resistance 3,55 ohm Voice coil inductance, 1 kHz 0,21 mH Magnet system Vented hybrid Max. linear excursion, X max +- 3,5 mm Max. peak to peak excursion, X max +-7mm 350ron 0733901110 Fb/Cristian MCO |
Re: Midbasi DLS UP6
6 Attachment(s)
Nu am putut da edit
Re: Midbasi DLS UP6
vandute
se poate sterge multumesc:!: |
| All times are GMT +2. The time now is 11:16. |
