-   Difuzoare Auto (https://forum.4tuning.ro/557-difuzoare-auto.html)
-   -   Beyma Competition Series (https://forum.4tuning.ro/557-difuzoare-auto/429299-beyma-competition-series.html)
catalinionut229 02-07-16 17:59
Beyma Power-M6 (powerm6) Competition Series 6-1/2" Midbass
Two 6 1/2" Competition Series Midbass Drivers
Power Handling:
Peak: 400 watts per pair / 200 watts each
RMS: 200 watts per pair / 100 watts each
Woven kevlar cone woofer
Rubber surround
Designed especially for low to midrange frequencies output
Impedance: 4 ohms
1.5" Single 4 ohms voice coil
Frequency Response: 65-7000 Hz
Sensitivity: 92 dB
Beyma COMPRESSION TWEETERS CP-22
Nominal impedance 8 ohm
Minimum impedance 8.5 ohm 9 kHz
Re 6.1 ohm
Power capacity 25 W AES
Program power 50 W
Sensitivity 107 dB
Frequency range 4000-20000 Hz
Recom. crossover frequency 5 kHz or higher (12 dB/oct. min slope)
Dispersion HxV 40º conical
Voice coil diameter 37.6 mm 1.5 in
Flux density 1.55 T
BL factor 5.2 N/A
Diaphragm material Aluminium
CONSTRUCTIVE DETAILS
External diameter 102x102 mm 4x4 in
Depth 71 mm 2.79 in
Cutout diameter ø 92 mm 3.62 in
Bolt circle diameter 107 mm 4.21 in
Net weight 1.6 kg
crossovere
pret 520 lei
catalinionut229 05-07-16 08:11
Re: Beyma Competition Series
poze ..
catalinionut229 12-07-16 10:03
500 taxe incluse ...
catalinionut229 25-09-16 14:16
400 lei ...Costul transportului GRATUIT
