Dezmembrez Ford Fiesta V an fabr.2003, 1.25i 16V
Dezmembrez Ford Fiesta V 2003, 1.25i 16V,caroserie hatchback 4+1 usi
Motorizare : - 1.25i 16V 55kw(75cp), tip FUJ Dotari : Cutie de viteze 5+1 trepte, geamuri si oglinzi manuale, jante tabla R15 195/50, carlig de remorcare, CD-Player, Radiocasetofon, 2x Airbag Elemente de caroserie: aripa fata, capota motor, capota portbagaj, hayon, bara fata, bara spate, portiera, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; Elemente optice: luneta, far, oglinda electrica, oglinda manuala, semnalizator, stop / lampa / tripla, parbriz, geam portiere; Anexe motor: compresor aer conditionat, alternator, chiuloasa, bloc motor, baie ulei, pompa servodirectie, turbosuflanta, galerie admisie / evacuare, electromotor, pompa benzina / motorina, piston, pompa injectie, suport motor, electrovalva, vibrochen, pompa ulei, injector, biela; Elemente de directie / suspensie / tren rulare: fuzeta, bara stabilizare, arc elicoidal, caseta directie, bascule, brat roata, jug motor,punte spate, telescop, pompa servo directie, port-fuzeta; Elemente racire: electroventilator ac / clima, radiator intercooler, termoflot, electroventilator habitaclu, electroventilator apa, radiator clima, radiator apa, racitor ulei; Elemente de siguranta: airbag sofer, airbag pasager, airbag lateral, calculator airbag / centralina, centura de siguranta, pretensionare centura, plansa bord, capac airbag pasager; Elemente de interior: scaun sofer / pasager, bancheta, cal, cotiera, torpedou, plansa bord, plafon textil, mocheta habitaclu, plafoniera, parasolar, tetiera; Elemente transmisie: cutie de viteze, placa ambreiaj, disc ambreiaj, volanta, rulment presiune, planetara; Elemente frana: etrier frana, suport etrier, disc frana, pompa servo frana, tulumba frana, pompa ABS, pompa vacuum; Elemente electrice: ceas de bord, contact pornire, panou comanda ac / clima, instalatie motor, calculator motor, kit pornire, macara geam, broasca usa, debitmetru aer, motor stergator fata / spate; |
