-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   Digital Design M3 (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/423453-digital-design-m3.html)
catalinionut229 22-06-15 17:11
Digital Design M3
Digital Design M3
Tested Voltage 14.4V
Tested THD 1%
Power at 4 ohm 600W
Power at 1 Ohm 2400W
Maximal Power 4500W
Damping Factor >450
Efficiency thru Output >85%
Signal to Noise 90dB
Input Sensitivity 0.2V - 8V
Subsonic Filter
10Hz - 50Hz at 24dB/Oct
Variable Low Pass Filter
20Hz - 200Hz at 24dB/Oct
Clipping Display LED
Dimensions, mm
540 L x 235 W x 53.4 H
Weight 11Kg
stare foarte buna fara zgarieturi sau probleme ascunse... amp dduce min 3K la 1 ohm merge si la 0,25 cautati mai multe pe net..
pret - 400 E
catalinionut229 01-07-15 16:02
Re: Digital Design M3
Vandut! ms
