-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   amplificator Genesis Profile 4 (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/422669-amplificator-genesis-profile-4-a.html)
dragos1111 17-05-15 08:43
Se adauga la vanzare amplificator Genesis Profile 4
- 500lei
Pretul este fix, si nu va scadea in timp, chiar daca nu se vinde in cateva luni.....
Pentru expediere prin curier/posta este posibil sa cer achitarea transportului in avans, scazand din pret acest avans.
Predare personala in Prahova, curier/posta in restul tarii.
Stare optica -8,5
Stare tehnica - 10
Produsul este folosit, a fost dezasamblat, curatat, inlocuita pasta termoconductoare, carcasa lustruita.
Au fost probate toate functiile, in toate configuratiile 4/3/2 canale.
Smart Switching -Automatically routes the signal
Thermal bias tracking -Eliminates distortion
Flexi-mount system -For easy installation
Vari-speed Thermal management -Quietly keeps everything cool
DC Sub level control -Eliminates noise pickup
Power Levels [2 Ohms] -1 x 70w
Power Levels [4 Ohms] -1 x 50w
Bridge -2 x 140W
THD -<0.1%
Signal to Noise Ratio -100dB 'A' Wtd
Input Sensitivity [Volts RMS] -0.3 ~ 4 Volts
Current Draw @ 4 Ohms -20 Amps
Fuse Rating -25 Amp
Crossovers HP [All Continuous] - CH 1 & 2 - 20 - 200 Hz
Crossovers HP [All Continuous] - CH 3 & 4 - 20 - 200 Hz
Crossovers LP [/- Module] - CH 3 & 4 -50 Hz sau 100Hz
Dimensions H x W x D [mm]* - 38 x 300 x 217
Weight [Kg] -2.0
https://olx.ro/oferta/amplificator-au...0-ID3SEo4.html
dragos1111 18-10-15 20:42
Re: amplificator Genesis Profile 4
Valabil, 450 lei negociabil
