JL Audio E1200
vand amplificator clasa AB JL Audio E1200, monobloc, este al unui prieten are tot la el, cutie originala, poze reale la cerere, se trimite prin ce doreste cumparatorul, acesta fiind achitat de cumparatorul, specificatii
Class AB Monoblock Full Range Amplifier Patented Absolute Symmetry dual N-Channel MOSFET output design Pass-through RCA outputs State-variable, 12dB/Oct Butterworth crossover with continously variable cutoff frequency selection from 50 - 200Hz. Configurable as High or Low pass Filter High level inputs CEA-2006 Compliant RMS Power Rating: 200 watts x 1 chan. at 2 Ohms 120 watts x 1 chan. at 4 Ohms Frequency Response: 10Hz - 25kHz Damping Factor: >200 @ 4 Ohms / 50Hz Slew Rate: +- 22V/us Input Range: 200mV - 8V RMS Bass Boost: 0 - 6dB (0 - 18dB with Bass remote - Not Included) Dimensions: 9.8" L x 9.25" W x 2.36" H pret 500ron info pe pm, sau la 0745086800 |
| All times are GMT +2. The time now is 13:11. |
