Vand amlificator 4 canale HELIX H400 ESPRIT
Perfecta stare de functionare cat si estetic, amplificator pt SQ
Detalii tehnice: Output 4 ohms RMS / maximum 4 x 70/85 watts - Output power 2 ohm RMS / maximum 4 x 100/150 Watt - Bridged output at 4 ohms RMS / maximum of 2 x 200/300 Watt - The frequency range 20 Hz - 20 kHz - 100 dB THD - Input Impedance 10 kOhm - Input Sensitivity 700 mV - 8 V - External fuse 2 x 25 A - Dimensions (H x W x D) 31.5 x 200 x 336 (mm) - Weight 2.6 kg pret 550 lei Tel. 0741201341 |
Re: Vand amlificator 4 canale HELIX H400 ESPRIT
vandut
