Dezmembrez Audi A3 (8L) 1997-2003 1.6i, 1.8i, 1.9 TDI - 0723364267
Dezmembrez Audi A3 (8L) an fab 1997-2003 1.6i, 1.8i, 1.9 TDI, 1.9 TDI PD, caroserie 2+1 usi hatchback.
Motorizari: - 1.6i 74kw (100cp) tip AEH, AKL, APF - 1.8i 20V 92kw (125cp) tip AGN, APG - 1.9 TDI 66kw (90cp) tip AGR, ALH - 1.9 TDI 81kw (110cp) tip ASV, AHF - 1.9 TDI PD 96kw (131cp) tip ASZ - 1.9 TDI PD 74kw (101cp) tip AXR, ATD. Dotari : cutie de viteze manuala 5+1 si 6+1 trepte si automata, ABS, ESP, incalzire in scaune, geamuri si oglinzi electrice, inchidere centralizata, jante tabla si aliaj R14, R15, R16 si R17, Aer Conditionat A/C, Climatronic, 4X Airbag, eleron. Livrarea se face prin curierat rapid in 24H. Toate piesele beneficiaza de 30 de zile garantie. Tel: 0723364267 Ym : constantadezmembrari@yahoo.com Elemente de caroserie: aripa fata, capota motor, capota portbagaj, hayon, bara fata, bara spate, portiera, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; Elemente optice: luneta, far, oglinda electrica, oglinda manuala, semnalizator, stop / lampa / tripla, parbriz, geam portiere; Anexe motor: compresor aer conditionat, alternator, chiuloasa, bloc motor, baie ulei, pompa servodirectie, turbosuflanta, galerie admisie / evacuare, electromotor, pompa benzina / motorina, piston, pompa injectie, suport motor, electrovalva, vibrochen, pompa ulei, injector, biela; Elemente de directie / suspensie / tren rulare: fuzeta, bara stabilizare, arc elicoidal, caseta directie, bascule, brat roata, jug motor,punte spate, telescop, pompa servo directie, port-fuzeta; Elemente racire: electroventilator ac / clima, radiator intercooler, termoflot, electroventilator habitaclu, electroventilator apa, radiator clima, radiator apa, racitor ulei; Elemente de siguranta: airbag sofer, airbag pasager, airbag lateral, calculator airbag / centralina, centura de siguranta, pretensionare centura, plansa bord, capac airbag pasager; Elemente de interior: scaun sofer / pasager, bancheta, cal, cotiera, torpedou, plansa bord, plafon textil, mocheta habitaclu, plafoniera, parasolar, tetiera; Elemente transmisie: cutie de viteze, placa ambreiaj, disc ambreiaj, volanta, rulment presiune, planetara; Elemente frana: etrier frana, suport etrier, disc frana, pompa servo frana, tulumba frana, pompa ABS, pompa vacuum; Elemente electrice: ceas de bord, contact pornire, panou comanda ac / clima, instalatie motor, calculator motor, kit pornire, macara geam, broasca usa, debitmetru aer, motor stergator fata / spate; https://forum.4tuning.ro/picture.php?...ictureid=63740 https://forum.4tuning.ro/picture.php?...ictureid=63739 |
