Audison Lrx2.250
Se vinde amplificatorul in stare perfecta,o sa revin si cu poze.
Pret : 430Ron Nominal output power (RMS) NP @ 12VDC; THD 0.3%: . . . . . 100W x 2 (4 Ohms) Output power (RMS) @ 13.8 VDC;THD 1% - A config.: . . . . . . . . . . . . . . . . . . 120W x 2 (4 Ohms) - B config.: . . . . . . . . . . . . . . . . . . 210W x 2 (2 Ohms) - C config.: . . . . . . . . . . . . . . . . . . 420W x 1 (4 Ohms) FILTERS/INPUTS IN L/R: Bypass/ 12dB/Oct. Hi-Pass/Lo-Pass (40 ÷ 500 Hz/400 ÷ 5000 Hz) Pre Out: Bypass/ 12dB/Oct. Hi-Pass/Lo-Pass (40 ÷ 500 Hz/400 ÷ 5000 Hz) Fuse: . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 A MAX SIZE (L x H x D): 176X56X300 mm WEIGHT:. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0 kg |
Re: Audison Lrx2.250
si poza cu amplificatorul :
Vandut!
| All times are GMT +2. The time now is 03:51. |
