Vand 2 amplifuri
Vand amplificator Lanzar max pro mxa 242 1600w,plus telecomanda ,in stare foarte buna.
2 x 400 Watts RMS at 4 Ohms 2 x 800 Watts MAX at 4 Ohms 1 x 1600 Watts MAX at 4 Ohms Bridged 2 x 650 Watts at 2 Ohms RMS Electronic Crossover Network Bass Boost Circuit Variable Phase Shift Control 2 Ohms Stereo Stable Anti-Thump Turn-On Soft Turn On/Off High Low Level Inputs Blue Light Illuminated Crossover Control Power Protection LED Indicators Advanced Protection Circuitry Bass Boost Remote Control T.H.D: < 0.04% S/N Ratio: >90dB Channel Separation: >65dB Frequency Response: 15Hz- 35kHz Dimensions: 10.47''W x 2.46''H x 15''L -350Ron mplificator Ground Zero GZTA 2. 150MK2, 2 x 75W (4 ohmi) 2 x 115W (2 ohmi) stabil in 2 ohmi in punte, 4 ohmi: 1 x 230W RMS modul alimentare MOSFET raspuns in frecventa: 5Hz - 30KHz filtru LPF variabil: 50 - 250Hz filtru HPF variabil: 50 - 250Hz bass boost: +6dB / +12dB (50Hz) dimensiuni: 287 x 254 x 50mm -280Ron Contact:0751 473 775 sau mesaj privat. Se vand pentru ca va urma un upgrade. |
| All times are GMT +2. The time now is 18:00. |
