Difuzoare Magnat, DLS, Clarion
Difuzoare:
1) Magnat Car Fit Style 132 NOI -90 lei boxe coaxiale pe 2 cai diametru : 13 cm putere rms : 45 W putere max : 180 W raspuns in frecventa : 44-20000 Hz frecventa crossover : 4400 Hz spl : 90 dB woofer cu con din celuloza tratata tweeter cu invelis din titan adancime instalare : 46 mm http://i61.tinypic.com/2sbtjq8.jpg 2) DLS REFERENCE Classic 424 NOI - 250 lei difuzoare coaxiale pe 2 cai diametru: 10 cm, tweeter 20 mm silk dome putere: 50W RMS / 80W max raspuns in frecventa: 65 - 20.000 Hz sensibilitate: 94 dB (1W/1m) crossover: LP 6 dB & HP 12 dB http://i62.tinypic.com/2hf17vo.jpg 3) Difuzoare JBL CS-762 - 105 lei Difuzoare Auto 2 Cai Diametru Woofer 16,5 cm Tweeter 16 mm Putere Maxima 135 W Putere Nominala (RMS) 45 W Impedanta 4 ohmi Raspuns Frecventa 55Hz – 20kHz Sensibilitate 93 dB Adancime instalare 59 mm Magnet 5 oz Nu includ grile plastic http://i61.tinypic.com/13z3060.jpg 4) DLS Reference PS5A sistem difuzoare 2 componente diametru woofer: 13 cm (5,25") putere RMS: 50W putere Max: 80W impedanta: 4 ohmi sensibilitate: 92 dB (1W/1m) tweeter T25, 25 mm (1") crossover: filtre LP 6 dB & HP 12 dB Pret 325 lei http://i59.tinypic.com/2iabxuv.jpg 5) Magnat Edition 693 - Pret 139 lei Difuzoare triaxiale 3 cai, 6" x 9" Impedanta 4 Ohmi Dimensiuni: 6" x 9", 13 mm tweeter Putere RMS 65W / MAX 260W Raspuns in frecventa: 40 Hz - 20.000 Hz Frecventa crossover: 2.500 / 4.500 Hz Nivel presiune sunet: 91 dB Adancime de instalare: 7.6 cm Diametru exterior: 25.7 x 18.7 cm Decupare: 22.2 x 15.2 cm http://i60.tinypic.com/aziam9.jpg 6) DLS Classic C5A sistem difuzoare 2 componente diametru woofer: 13 cm putere RMS: 50W putere Max: 80W impedanta: 4 ohmi raspuns in frecventa: 60 - 20.000 Hz sensibilitate: 93 dB (1W/1m) tweeter T20, 20 mm crossover: low pass 12 dB & high pass 12 dB tehnologie DLS EFR (Enhanced Frequency Response) PRET 330 LEI !!! http://i62.tinypic.com/ml04uu.jpg 7) DLS Classic C5 - 300 lei sistem de difuzoare pe 2 cai diametru woofer 13 cm tweeter T20, 20 mm putere 50W RMS / 80W max raspuns in frecventa: 60 - 20.000 Hz sensibilitate: 93 dB (1W/1m) impedanta: 4 ohmi crossover: low pass 12 dB & high pass 12 dB Nu am crossoverele originale dar ofer un set de crossovere noi, tot de la un set dls. http://i59.tinypic.com/1fft4z.jpg 8) Clarion SRG 5733C DIFUZOARE COAXIALE PE 3 CAI 5"x7" (13x18cm) ・ Gestionarea puterilor maxime în redare (250 waţi) ・ Woofer conic MIPP de 130 × 180 mm ・ Unitate de medii cu difuzor echilibrat PEI metalizat de 25 mm ・ Tweeter în formă de dom de 8 mm ・ Magnet din stronţiu puternic pentru un răspuns dinamic al basului ・ Conceput pentru înlocuire OEM directă Caracteristici tehnice: Putere muzicală de vârf (W): 250 Eficienţă (dB/W/m): 91 Răspuns în frecvenţă (Hz): 35~32.000 Adâncime de montare (mm): 52,5 Pret 105 lei http://i59.tinypic.com/ao57d5.jpg 9) Magnat Car Fit Style 216 boxe sistem cu 2 cai diametru mid-bass : 16.5 cm putere rms : 60 W putere max : 240 W impedanta : 4 ohmi raspuns in frecventa : 37-22000 Hz frecventa crossover : 4400 Hz spl : 91 dB woofer cu con din celuloza tratata tweeter cu invelis din titan adancime instalare mid-bass : 55 mm Pret 150 lei http://i60.tinypic.com/1zldgkx.jpg 10) DLS Classic B5A - DOAR MID-BASS ( + filtre) !!! sistem difuzoare 2 componente diametru woofer: 13 cm putere RMS: 50W putere Max: 80W impedanta: 4 ohmi raspuns in frecventa: 60 - 18.000 Hz sensibilitate: 91 dB (1W/1m) tweeter: 16 mm crossover: low pass 12 dB & high pass 12 dB tehnologie DLS EFR (Enhanced Frequency Response) Pret 200 lei http://i61.tinypic.com/2zejb5f.jpg 11) Magnat Profection 213 - 199 lei boxe sistem diametru mid-bass : 13 cm diametru tweeter : 13 mm putere rms : 70 W putere max : 280 W impedanta : 4 ohmi raspuns in frecventa : 43 - 26000 hz frecventa crossover : 4000 hz spl : 90 dB adancime instalare mid bass : 42 mm http://i61.tinypic.com/2emprx0.jpg |
Re: Difuzoare Magnat, DLS, Clarion
s-a dat setul DLS PS5A
Magnat Car Fit Style 216 le mai ai ?
Un pret final ? Pentru logan trebuie si inele mdf pentru motaj portiere fata,nu ? |
140 lei pret final
Nu am inele adaptoare |
Un nr de telefon ? Merci
salut colegu, ai da separat un set de twetere si filtre dls?
stima! |
salut
momentan nu dau separat o seara placuta! |
Salut, mai ai JBL-urile? daca da, livrate la Arad cu Posta Romana 100 lei cu transport inclus ar merge?
salut
da le mai am din pacte la jbl pretul este fix deci daca doresti la 120 lei lei cu tot cu transport imi lasi adresa pe privat si le expediez prin posta |
salut,
ce mai este disponibil? Mersi |
salut
disponibile momentan mai sunt asa: perechea DLS B5A o pereche de magnat edition 216 la 150 lei 2 perechi de jbl gt6-69 la 175 lei setul |
