Amplificator DLS Reference RA30 - 565 Watts, 3-ch amplifier
REFERENCE series RA30 is a 3- channel amplifier rated at 2 x 70 + 1 x 265 Watts.
- Built- in variable 40- 125 Hz switchable low pass filter for subwoofers. - Built- in/ switchable variable 45- 125 Hz high pass filter that can be used as a subsonic filter or high- pass filter for front systems. - Grand bass 0- 18 dB. - Phase shift control. - Remote level and phase control included - High level input with automatic start. - RMS output per channel at 13, 8 volts, 20 Hz - 20 kHz , < 0, 1% distortion. Specifications Amplifier class AB Output power in 4 ohm 2 x 70 W RMS Output power in 2 ohm 2 x 100 W RMS Mono sub channel 4 ohm 265 W RMS Mono sub channel 2 ohm 365 W RMS S/ N ratio, A- weighted > 100 dB Frequency range 10 Hz - 50 kHz Input sensitivity 0, 2 - 7 V Input impedance < 10 kohm Input impedance, high level 330 ohm Filters channel A & B HP: 45 - 125 Hz Filter sub channel LP: 40 - 125 Hz Phase control for subwoofers 0- 180 degrees variable Grand bass filter 0- 18 dB @40 Hz High level input with auto start Yes Power consumption (idle) 0, 9 A Power consumption (max) 70 A Rec. power cable Minimum 4AWG / 21 mm2 Fuses 2 x 35 A Dimension (W x D x H) 385 x 245 x 59 mm (15, 15 x 9, 65 x 2, 33 inch) Weight 4, 4 kg ( 9, 7 lb) stare impecabila include si remote! Pret 900 ron |
Re: Amplificator DLS Reference RA30 - 565 Watts, 3-ch amplifier
pret discutabil ...
800 ron ....
750 ron ...
700 ron ...
650 ron ...transp inclus!
poze ...
vandut!
| All times are GMT +2. The time now is 18:15. |
