focal 30a1
dif subwoofer focal 30a1 Pret: 180 ron
Features Woven Glass Fiber Cone: The FOCAL Access 30A1 features a 12" a braided and watertight, all-weather, woven glass fiber cone for dynamic bass response between 27-500Hz. Butyl Surround: The FOCAL Access 30A1 features a butyl rubber surround to promote long life and durability. 2" Voice-Coil: The Access 30A1 woofer features a 4-layer, 2" voice-coil for higher power handling capabilities up to 250 watt (RMS) and 500 watt (Peak). Voice Coil Cooling System: The Access 30A1's voice-coil cooling system provided optimized reliability with no dynamic compression. 145mm Magnet: The Access 30A1 woofer features a 145mm (5.708") magnet for higher sensitivity up to 94dB (2.83V/1m). Spring-Posts: The FOCAL 12" woofer is equipped with a pair of spring-post speaker terminals for easy connection up to 10AWG wire. Rubber Gasket: The Access 30A1 features a rubber gasket mounting-ring for better chassis damping and to prevent air leakage. The rubber gasket is removable. Rubber Magnet Boot: The Access 30A1 features a rubber magnet boot to protect the woofer's magnet from shocks and corrosion. The rubber boot is removable. |
Re: focal 30a1
155 noul pret
Re: focal 30a1
150 ron.
Re: focal 30a1
Dat sa il foloseasca cu brio.
| All times are GMT +2. The time now is 07:23. |
