Se vand 2 Pb 1500w
Se pun la vanzare 2 subwoofere Power Bass m-124
*VC impedance (Ohms) - 4Ω Test Impedance (Ohms) - 3.2 Fs (Hz) - 29 SD (sqCM) - 510.7 Vas (Ltr) - 77.3 Cms (M/N) - 212.2 Mms (g) - 139.1 BL - 13,6 Qms - 3.6 Qes - 0.46 Qts - 0.41 No(%) - 0.32 Spl(db) - 92 Xmax - 9.5 Voice coil size (inches) - 2.0 Frequency response (Hz) - 29-450 Motor structure - 164 oz Mounting Depth - 5.5 power (rms/peak) - 375/750* -Mentionez difuzoarele sunt fara incinta -Proba se face pe masina clientului doar in bucuresti -Sunt in stare perfecta atat estetic cat si functionala -Accept schimburi doar cu componente pe 3cai Pret 600 lei ambele 350 lei buc |
Re: Se vand 2 Pb 1500w
Valabil!
Daca si petardele alea au 1500 watt..da-o dreaq..
| All times are GMT +2. The time now is 01:52. |
