Opel Video Interface DVD800 DVD600 CD500 Insignia AstraJ HDMI
New iCIDLink7 - Opel & Vauxhall Multimedia Interface with HDMI
Overview The iCIDLink7 unit is a multimedia interface adaptor for Opel wide16:9 CID (Color Info Display) OEM available in car providing video & audio input auxiliary and allowing you in combination with external video devices (e.g Android TV box, MirrorLink box, CarPC, Car GPS Box, etc) to use CID as a smart display. This adaptor is a professional and quality product that allows you to integrate an external Video source to your cars factory fitted CID Screen. Once connected it gives you the ability to connect an In car DVD player, iPod Video, Media Player, Android TV box, MirrorLink box, CarPC, DVB-T TV Tuner, Rear View Camera, Car Navigation GPS box, etc to keep your passengers entertained. The KIT is available with one year and half warranty. Each device is being tested before shipment. After you receive the KIT, we'll assist you through mail or chat to install and configure the interface. We'll guaranty you a professional customer support, answering in the same day and doing all our best to get the interface running well in your car. Features and Capabilities 1.Compatible to OEM CID 7inch screen available for Insignia (2008-2013), AstraJ (2010 -2013), MerivaB (2011-2013), Mokka (2012-2013), Zafira Tourer (2011-2013) connected to the following entertainment head units: DVD600, DVD800 NAVI, DVD900 NAVI. 2. Watch any video source on your original Factory fitted CID Screen Plug & play installation with OEM connectors. No need to cut any wire or to open the display. 3. The interface accepts the following video and audio signals: Two AV video and audio input: 1 x RCA for CVBS(Composite) video input, 2 x RCA for audio input. 1 x socket jack 3.5mm 4 ways. NTSC and PAL TV system format: NTSC (M, 4.34) and PAL (B, D, G, H, I, M, N, N combination), PAL (60) with automatic format detection. One PC VGA video input (DB15) and one jack PC Audio input One HDMI 1.1 compliant input One video input (RCA CVBS/Composite) for rear view camera. One audio output, multiplexing AV1,2 Audio_in, PC Audio_in and HDMI audio. To be connected to aux-in of DVD Navi. 4. Wide 16:9 image format. 5. Digital Video processor with dynamic contrast control providing high quality picture. 6. Switch voltage 5V/1A output controlled from OEM menu for powering supply of external devices (e.g. Android TV box) 7. OSD menu for picture parameters settings using remote control 8. OSD menu for enable/disable each video/audio input. 9. Factory OSD for advanced picture parameters 10. Factory reset: restore image parameter to factory default. 11. Automatic detection of video input signals. Blue screen for video inputs without signals. 12. Automatically switch and display the view from rear view camera when the car is placed in the reverse. 13. Low Power consumption during video processing. 14. Touch sensor/pad for selection of video sources. Can be hidden in dash under a plastic panel. Video Interface Kit Part List 1.Multimedia Interface box 2.Video cable for OEM CID display 3.IR extension cable 4.IR Remote control 5.Power& Control cable for power supply, touch/proximity sensor signal, rear view camera signal, 5V DC out, audio out signals. 6.Installation Manual Please don't hesitate to contact us for any questions and clarifications. office@energys.ro |
Re: Opel Video Interface DVD800 DVD600 CD500 Insignia AstraJ HDMI
I accept crypto coins payment: BTC, ETH, LTC
