Medii Hybrid Audio
Vand un set medii de 12cm Hybrid Audio Technologies,unii prin State le compara cu Scanspeak 12M.Se afla in stare buna de functionare.
Pentru pret ma contactati pe privat. Overall diameter: 118mm (4.65-inch) Mounting depth: 54mm Bolt Circle Diameter: 109.5mm Mounting hole: 94.5mm Pmax: 60W Pmax (with recommended crossover): 200W Frequency range: 90Hz - 17,000 Hz Sensitivity: 89dB (2.83V/1m) Mms: 4.22g Cms: 706.4 um/N BL: 3.74 T*m Voice coil diameter: 25.5mm (1-inch) Impedance: 4 Ohm DC Resistance: 3.4 Ohm Fs: 90Hz (free air) Qms: 2.61 Qes: 0.61 Qts: 0.50 Xmax: 2.5mm (one way) Vas: 2.54L Sd: 5000mm |
Re: Medii Hybrid Audio
Sus cu ele ...pret mic
300 lei! nu au nici un defect
Nimeni nimic?
Un up! asa de control
| All times are GMT +2. The time now is 18:52. |
