Vand pachet 141+ db
8 Attachment(s)
De vanzare:
Amp mic: Hollywood HXA 20 Amplificator 2 canale, clasa A/B Putere Nominala(RMS): 2 x 100 W - 4 ohmi 2 x 175 W - 2 ohmi 1 x 350 W - 4 ohmi ( in punte ) Raport semnal/zgomot >80dB Raspuns in frecventa 15Hz~25KHz Distorsiuni THD <0,05% ( la puterea maxima ) Filtru Subsonic 15-50Hz Filtru High pass 20Hz~250Hz Filtru Low pass 20Hz~250Hz Sensibilitate intrare:200mV-5V Impedanta de intrare 22Kohm Pornire Soft-Start Sigurante 1 x 40A Protectie la supra-voltaj, scurt-circuit, inversarea polaritatii si supra-incalzire Dimensiuni:200 x 140 x 54 mm Amp mare: Monacor CarPower D-Rex 3000 Max. power 3,000WMAX RMS power 2O 1 x 2,500WRMS RMS power 4O 1 x 1,500WRMS Frequency range 20-150Hz Load impedance (min.) 2O Input sensitivity (line) 0.3-8V S/N ratio > 85dB THD < 0.5% Low-pass 40-150Hz, 24dB/oct. Subsonic 15-50Hz, 18dB/oct. Bass boost 30-60Hz, 0dB - (+6dB) Operating voltage 11-16V DC current /200A Connections screw terminals Line 1 x RCA L/R Speakers screw terminals Line 1 x RCA L/R Remote control RJ45 Admiss. ambient temp. 0-45 °C Dimensions 300x60x565mm Weight 8.9kg Sub: RE AUDIO SE 15" Dual 2 ohm Voice Coils 1200 watts peak output 15" competition grade subwoofer 600 watts pure RMS Qes: .55 Qms: 4.3 Qts: .49 Free Air Resonance -Fs: 22 Hz Vas: 209 liters Overall Diameter - 15.65" Bolt Hole Circle - 14.85" Weight - 24 lbs. One-Way, Linear Excursion -Xmax: 18 mm Efficiency - 87.1 dB SPL @ 1w/m DC Resistance -Re: 2.8 ohm Mounting Depth - 7.75" Dual Composite 2-piece Cone Rubatek Foam Surround Cast Aluminum Basket Tork-Tite Terminal 3" 4-layer Aluminum Voice Coil FEA Optimized Motor Structure Triple Stack Maganets Progressive Spiders Wrap around Rubber Gasket Cutie: @46 hz MDF Volum si dimensiuni le pun maine. Cabluri: Hollywood HE-3024 5+1m 4GA PC 5m 12GA SC 2CH RCA Twisted 5m 18GA Remote 80A AGU Holder Terminal soldered Detalii minore: amp mic + sub & cutie scor 138+ (baterie varta silver 75amp, alternator stock) amp mare + sub & cutie scor 141+ (baterie varta silver 75amp, alternator stock) Se poate vedea/incerca in Arad Contact: telefon 0733 411 115 preferabil L-V dupa ora 16 mail x3m_5p33d3r@yahoo.com skype x3m_3p33d3r Pret: 2700 lei |
Re: Vand pachet 141+ db
2 Video cu ele in functiune
https://www.youtube.com/watch?v=bVTnxBtWEGo https://www.youtube.com/watch?v=r2HBonW0mKQ |
Dimensiunile cutiei:
Lungime 950 mm Inaltime 405 mm Adancime 440 mm |
Pret nou: 2400 tot
Pretul revine la 2700 lei
Pret nou: 2300 Lei
2100 Lei
1800 LEi
