Pachet MTX Subwoofer + Statie
Subwoofer MTX RT12DV
subwoofer in incinta bass reflex diametru difuzor: 30 cm putere RMS: 250W putere Max: 750W impedanta: 2x4 ohmi raspuns in frecventa : 30Hz - 150Hz sensibilitate: 92,4dB / 2,83V / 1m Xmax : 12,0mm dimensiuni: 37,0 x 50,0x 41,5cm (HxWxD Amplificator MTX RT602 Road Thunder Series 2-Channel Class AB Car Amplifier RMS Power Rating: 4 ohms: 60 watts x 2 chan. 2 ohms: 90 watts x 2 chan. Bridged, 4 ohms: 180 watts x 1 chan. Masuratorile de putere au caracter independent de producator (MTX) si sunt facute de catre CEA; toate specificatiile privind puterile amplificatoarelor MTX Thunder 2008 sunt redacate si certificate de catre CEA Filtru Low Pass variabil - 24dB/octava de la 40Hz la 400Hz Filtru High Pass variabil - 24dB/octava de la 40Hz la 400Hz PRET : 450 Ron Valabil doar Bucuresti , predare personala. TEL : 0760.53.90.59 |
Re: Pachet MTX Subwoofer + Statie
Statia s-a vandut!
mai ramane doar Subwooferul MTX - pret 230 lei |
| All times are GMT +2. The time now is 10:53. |
