tweetere Peerless RDC2000 100w 4 ohmi noi, sigilate!
vand/schimb doua tweetere Peerless sigilate. Voi reveni cu poze reale.
Thiele Small parameters: Nominal impedance Zn (ohm) 4 Minimum impedance/at freq. Zmin (ohm/Hz) 3.2/3500 Maximum impedance Zo (ohm) 4.0 DC resistance Re (ohm) 3.0 Voice coil inductance Le (mH) 0.1 Resonance Frequency fs (Hz) 1400 Mechanical Q factor Qms 1.13 Electrical Q factor Qes 3.53 Total Q factor Qts 0.86 Mechanical resistance Rms (Kg/s) 1.26 Moving mass Mms (g) 0.16 Suspension compliance Cms (mm/N) 0.08 Effective cone diameter D (cm) 2.6 Effective piston area Sd (cm²) 5.3 Force factor Bl (N/A) 1.1 Reference voltage sensitivity Re 2.83V 1m at 3500 Hz (Measured) (dB) 91.5 Magnet and voice coil parameters: Voice coil diameter d (mm) 13 Voice coil length h (mm) 1.8 Voice coil layers n 2 Flux density in gap B (T) 1.0 Total useful flux (mWb) 0.1 Height of the gap hg (mm) 2.5 Diameter of magnet dm (mm) 40 Height of magnet hm (mm) 7.5 Weight of magnet (kg) 0.04 Power handling: Long term Max System Power (IEC) (W) 100 Relatii la tel: 0751488830 - Claudiu. |
Re: tweetere Peerless RDC2000 100w 4 ohmi noi, sigilate!
poze reale cu tweeterele:
