Audison LR 435
TECHNICAL DATA
POWER SUPPLY 11 - 15 VDC IDLING CURRENT 0.8 A MAX CONSUMPTION (4 Ch x 4 Ohms) 4 x 20 A MAX IMPULSIVE CONSUMPTION 35 A DISTORTION THD (1 KHz) 0.07 % OUT POWER CONT. (4 Ch x 4 Ohms) 4 x 35 W (RMS) OUT POWER CONT. (4 Ch x 2 Ohms) 4 x 50 W (RMS) OUT POWER MONO (2 Ch x 4 Ohms) 2 x 100 W (RMS) OUT POWER CONT. (3 Ch x 4 Ohms) 35 + 35 + 100 W BANDWIDTH (-3 dB) 4 Hz - 70 KHz CROSSOVER FREQUENCY (LR 435 XR) 40 - 220 Hz FILTERS SLOPE (LR 435 XR) 12 dB/Oct. DAMPING FACTOR 120 RISE TIME 4.5 uS S/N RATIO (W "A") 98 dB INPUT SENSITIVITY 0.15 V - 1.5 V INPUT IMPEDANCE 15 KOhms OUTPUT IMPEDANCE EACH CHANNEL 2 - 4 - 8 Ohms OUTPUT IMPEDANCE MONO (BRIDGE) 4 - 8 Ohm REMOTE IN 3 - 16 VDC REMOTE OUT 12 VDC MUTE IN 3 - 16 VDC MUTE OUT 12 VDC SIZE (WxHxD) 175 x 50 x 290 mm (6.89 x 1.97 x 11.42 inch) WEIGHT 2.300 Kg (5.07 lbs) Pret 130 lei |
Re: Audison LR 435
upp!!
Re: Audison LR 435
Rezervata deocamdata pana luni !
| All times are GMT +2. The time now is 09:25. |
