Vand amplificator DLS CA31
Specifications Number of channels 3 Amplifier class AB Output power in 2 ohm 2 x 90 W RMS Output power in 4 ohm 2 x 65 W RMS Mono sub channel 2 ohm 280 W Mono sub channel 4 ohm 170 W RMS Damping factor >100 S/ N ratio, A- weighted >100 dB Frequency range 10 Hz - 35 kHz Input sensitivity 0, 25 - 5 V Input impedance >10 kohm Input impedance, high level 100 ohm Filters channel A & B HP: 50- 150 Hz Remote bass level control No Filter sub channel Lowpass: 50 - 120 Hz + subsonic 25 Hz Low level output No Remote phase shift control No Phase control for subwoofers 0- 180 degrees cont. variable High level input with auto start Yes Power consumption (idle) 1A Power consumption (max) 60A Rec. power cable Minimum 4AWG / 21 mm2 Fuses 2 x 30 A Dimension (W x D x H) 70 x 357 x 268 mm (2, 92 x 14, 06 x 10, 55 inch) Weight 4 kg pret:320 ron Tel:0745514218 |
Re: Vand amplificator DLS CA31
vandut,se poate inchide
| All times are GMT +2. The time now is 02:26. |
