Piese bmw e46 ieftine
Vand piese din dezmembrarea unui bmw din 2001:
-ews + ecu + contact :350ron -calculator airbag :100ron -senzor airbag lateral :50ron -airbag usa :100ron -airbag cortina :80ron -airbag pasager :100ron -electromotor : 200ron -alternator : 150ron -bobina + fise : 100ron -tampon motor :50ron -piesa tepi :100ron -banda volan :50ron -galerie admisie : 50ron -pompa servo :150ron -pompa abs : 100ron -pompa frana :100ron -cilindru ambreiaj :70ron -compresor a/c :150ron -capota portbagaj : 150ron -radiator a/c : 100ron -ventilator+ modul : 250ron -modul confort : 80ron -macara geam stanga fata: 100ron -buton geam usa : 30ron -buton geam consola : 50ron -buton oglinda : 30ron -buton avarii : 30ron -bloc lumina cu proiectoare : 70ron -capac rezervor :20ron -buson rezervor : 30ron -luneta :80ron -geam lateral : 30ron -pilot automat : 350ron -grup : 250ron -cardan : 100 -lampa stop frana :50ron -triple semnal alb : 200ron -bara spate + armatura : 150ron -cric :50ron -arc fata : 50 ron -arc spate : 50 ron -etrier fata : 60 ron -carcasa filtru aer : 30 ron -carcasa oglinda :30ron -prag : 50ron -tunel aer :20ron -scut motor aluminiu :100ron -toba finala : 100 ron Pentru alte detalii sunati-ma. Tel : 0762.676.922 |
Re: Piese bmw e46 ieftine
totusi, ce motorizare ?
1.9 benzina-M43
Deocamdata nu.Te anunt.
Salut,
Scut motor aluminiu. Pune te rog o poza cu el . Stii cumva daca merge si pe e46 coupe? sunt interesat ms. |
Nu stiu.
salut.
Ti'am lasat PM . Sunt interesat si de o trusa de chei comleta cu antifurt si tot ce trebuie . Daca ai sa imi zici in pret. MS |
Ti-am trimis scutul.
Poza la cod. |
| All times are GMT +2. The time now is 13:30. |
