Dezmembrez OPEL
10 Attachment(s)
Dupa cum spune titlul anuntului ,am luat o astra f ptr ceva piese si dezmembrez de pe dansa,preturi negociabile:
motor C16NZ la cheie cutie viteze piese caroserie (banchetele spate sunt de GSI in stare perfecta ) cam tot ce se vede. tel 0746 179120 0732 966709 |
Re: dezmembrez astra f
un pret pe caseta de directie daca o mai ai si daca e buna? mersi mult
e buna man dar nu e servo:(
preturi ( negociabile) aici: denumire piese / euro MOTOR 150 CUTIE VITEZE 50 ABS 50 ROTI 4 BUC 50 DELCOU 30 INJECTIE MONOPUNCT 20 FAR STANGA 10 FAR DREAPTA 12 SEMNALIZARI 12 STOP SPATE STANGA 25 STOP SPATE DREAPTA 25 TRAPA MANUALA 50 CAPOTA 30 PARBRIZ 50 LUNETA SPATE 40 BARA SPATE 12 BARA FATA 12 SCAUNE FATA 20 TETIERE GSI 12 VOLAN 12 BORD CHEL 12 MASCA FATA 5 RADIATOR 30 ELECTROMOTOR 40 HAION SPATE 30 MACARALE GEAM 20 REZERVOR 12 USA STANGA 20 USA DREAPTA 12 ARIPA STANGA 15 ARIPA DREAPTA 15 AMORTIZOR ST FATA 10 AMORTIZOR DR FATA 10 AMORTIZOR ST SPATE 10 AMORTIZOR DR SPATE 10 FATA USA STG 12 FATA USA DR 12 FATA INTERIOR SPATE ST 10 FATA INTERIOR SPATE DR 10 ALTERNATOR 40 PUNTE SPATE CU TAMBURI 35 CEASURI BORD 10 CONTACT + CHEIE 12 GEAM LATERAL STG 12 GEAM LATERAL DR 12 CENTURI SIGURANTA 10 PARASOLARE 5 CHEDERE USI 7 CABLU KILOMETRAJ 4 BOBINA INDUCTIE 12 VAS APA 2 CASETA DIRECTIE NONSERVO 24 BANDOURI LATERALE(SET 4 BUC) 12 MANERE USI (2 BUC) 12 CATALIZATOR 50 DISCURI+ETRIERI+PLACUTE VENTILATE 50 POMPA BENZINA 17 |
mersi oricum
UPDATE :
DENUMIRE PIESA RON CUTIE VITEZE 150 ABS 200 ROTI 4 BUC (CU GUME 175/70/13) 200 FAR STANGA CU SEMNAL 65 FAR DREAPTA CU SEMNAL 65 STOP SPATE STANGA 50 STOP SPATE DREAPTA 50 TRAPA MANUALA 160 CAPOTA 80 PARBRIZ 100 BARA FATA 50 SCAUNE FATA 80 TETIERE GSI 50 VOLAN 50 BORD CHEL 50 MASCA FATA 20 RADIATOR 150 ELECTROMOTOR 120 HAION SPATE CU LUNETA SI ELERON MIC 220 MACARALE GEAM 2BUC 80 REZERVOR CU POMPA BENZINA 100 USA STANGA 80 USA DREAPTA 80 ARIPA STANGA 50 ARIPA DREAPTA 50 AMORTIZOR ST FATA 50 AMORTIZOR DR FATA 50 AMORTIZOR ST SPATE 50 AMORTIZOR DR SPATE 50 ALTERNATOR 120 PUNTE SPATE CU TAMBURI 120 CEASURI BORD 40 CONTACT + CHEIE 50 GEAM LATERAL STG 50 GEAM LATERAL DR 50 CENTURI SIGURANTA 50 PARASOLARE 20 CABLU KILOMETRAJ 20 BOBINA INDUCTIE 50 VAS APA 10 CASETA DIRECTIE NONSERVO 80 BANDOURI LATERALE(SET 4 BUC) 60 MANERE USI (2 BUC) 50 CATALIZATOR 150 DISCURI+ETRIERI+PLACUTE VENTILATE 200 POMPA BENZINA 60 PLANETARA STG 65 |
UPDATE :
DENUMIRE PIESA / RON CUTIE VITEZE 150 ABS 200 ROTI 4 BUC (CU GUME 175/70/13) 200 FAR STANGA CU SEMNAL 65 FAR DREAPTA CU SEMNAL 65 STOP SPATE STANGA 50 STOP SPATE DREAPTA 50 TRAPA MANUALA 160 CAPOTA 80 PARBRIZ 100 SCAUNE FATA 80 BORD CHEL 50 MASCA FATA 20 RADIATOR 150 ELECTROMOTOR 120 HAION SPATE CU LUNETA SI ELERON MIC 220 MACARA GEAM DREAPTA 40 REZERVOR CU POMPA BENZINA 100 USA DREAPTA 60 AMORTIZOR ST FATA 50 AMORTIZOR DR FATA 50 AMORTIZOR ST SPATE 50 AMORTIZOR DR SPATE 50 ALTERNATOR 120 PUNTE SPATE CU TAMBURI 150 CEASURI BORD 40 GEAM LATERAL STG 50 GEAM LATERAL DR 50 CENTURI SIGURANTA 50 CABLU KILOMETRAJ 20 BOBINA INDUCTIE 50 VAS APA 10 CASETA DIRECTIE NONSERVO 80 BANDOURI LATERALE(SET 4 BUC) 60 MANERE USI (2 BUC) 50 CATALIZATOR 150 DISCURI+ETRIERI+PLACUTE VENTILATE 200 FUZETA DR CU RULMENT 60 FUZETA STG CU RULMENT 60 PLANETARA STG 65 ETC |
UPDATE:
DENUMIRE PIESA RON CUTIE VITEZE 150 ABS 200 ROTI BUC (CU GUME 175/70/13) 200 SEMNAL STG 10 SEMNAL DR 10 STOP SPATE STANGA 50 STOP SPATE DREAPTA 50 TRAPA MANUALA 160 CAPOTA 80 PARBRIZ 100 SCAUNE FATA 80 BORD CHEL 50 RADIATOR+VENTILATOR 150 ELECTROMOTOR 120 HAION SPATE CU LUNETA SI ELERON MIC 200 MACARA GEAM DREAPTA 40 REZERVOR CU POMPA BENZINA 100 USA DREAPTA 50 AMORTIZOR ST FATA 50 AMORTIZOR DR FATA 50 AMORTIZOR ST SPATE 50 AMORTIZOR DR SPATE 50 ALTERNATOR 110 PUNTE SPATE 50 CEASURI BORD 40 GEAM LATERAL STG SPATE 50 GEAM LATERAL DR SPATE 50 CENTURI SIGURANTA 50 CABLU KILOMETRAJ 20 BOBINA INDUCTIE 50 VAS APA 10 CASETA DIRECTIE NONSERVO 70 BANDOURI LATERALE(SET 4 BUC) 60 MANERE USI (2 BUC) 50 CATALIZATOR 150 DISCURI+ETRIERI+PLACUTE NEVENTILATE 150 FUZETA DR CU RULMENT 60 FUZETA STG CU RULMENT 60 PLANETARA STG 70 PLANETARA DR 70 ETC ETC ETC |
se mai adauga 4 jante 4x100 , nelovite si bezgariate , 100 euro.
Un id de mess se poate ? as fi interesat de furtunul dintre filtru de aer si injectie, vasul de apa de stergatoare+motorasul.
[QUOTE=sebastyan2001;2323560]Un id de mess se poate ? as fi interesat de furtunul dintre filtru de aer si injectie, vasul de apa de stergatoare+motorasul.[/QU
piesetm ,salut. |
9 Attachment(s)
update :
Cutie F13,eleron cu tot cu sprituitoare,caseta directie nonservo,ECU C16NZ,capota,trapa,catalizator,toba de mijloc...etc In link-ul de pe youtube este si motorul pus in vanzare cu tot cu instalatie si ECU, 250 e,in apele lui,fuge 200 kmh si se prezinta bine,il dau deoarece fac transplant. https://www.youtube.com/watch?v=mQINk...e=channel_page |
Eleron kadett
cu tot cu suruburi, stare perfecta , 150 ron.
Up, mai e piese :D ,parbriz,stopuri,EGR, elemente interior.etc.
un ultim pret pt radiator fara ventilator mersi
