-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   Vand statie+subwoofer (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/387308-vand-statie-subwoofer.html)
PetricaCBD 06-09-13 09:34
Vand pachet statie+subwoofer:
-Vand amplificator auto Sony 4 canale
Specificatii: Circuit system: OTL (output transformerless) circuit Pulse power supply Inputs: RCA pin jacks High level input connector Input level adjustment range: 0.3 - 6 V (RCA pin jacks), 1.2 -12 V (High level input) Outputs: Speaker terminals Speaker impedance: 2-8 Ω (stereo) 4 - 8 Ω (when used as a bridging amplifier) Maximum output: Four speakers: 100 W x 4 (at 4 Ω) Three speakers: 100 W x 2 + 250 Wx1(at4Ω) Rated output (supply voltage at 14.4 V): 55 W RMS x 4 (DIN 45500,4 Ω) Four speakers: 50 W RMS x 4 (20 Hz - 20 kHz, 0.04 % THD, at 4 Ω) 60 W RMS x 4 (20 Hz - 20 kHz, 0.1 % THD, at 2 Ω) SN Ratio: 100 dBA (reference: Rated output) Frequency response: 5Hz - 50 kHz Harmonic distortion: 0.005 % or less (at 1 kHz, 4 Ω,10 W) Low-pass filter: 80 Hz, - 18 dB/oct High-pass filter: 80 Hz, -12 dB/oct Power requirements: 12 V DC car battery (negative ground) Power supply voltage: 10.5 -16 V Current drain: 30 A (at 4 Ω, 50 W x 4) Remote input: 1 mA Dimensions Approx. 350 x 55 x 238 mm (w/h/d) Mass Approx. 3.1 kg not incl.
Ideal pentru 2 boxe+subwoofer,ofer proba,se afla montat pe masina pentru proba(singurul proprietar,il am de nou,am tot la el)
- subwoofer JBL 1204t in incinta bass reflex(tub)
diametru woofer: 12" (30 cm)
putere RMS: 250 W
putere maxima: 1000 W
impedanta: 4 Ohmi
raspuns in frecventa: 35-200Hz
diametru tub: 330 mm
pret:550 ron setul
telefon:0760.991.910
PetricaCBD 16-09-13 15:56
Re: Vand statie+subwoofer
scade la 500 ron setul
PetricaCBD 17-09-13 19:12
Ramane doar statia la 200 ron
PetricaCBD 19-09-13 22:22
Vandute!SE poate inchide.Multumesc 4tuning
