De vanzare Statie Pioneer GM-X334
Continuous Power (20Hz-20kHz, 0.08% THD)
4 ch: (4 Ohm) 30Wx4 4 ch: (2 Ohm) 35Wx4 2 ch: (4 Ohm) 70Wx2 Maximum Power (EIAJ) 4 ch: (4 Ohm) 60Wx4 2 ch: (4 Ohm) 140Wx2 Frequency Response: 10Hz - 45kHz (0,-1dB) Total Harmonic Distortion: 0.008% (1kHz, 4ohm ) Signal-to-Noise Ratio: 106dB (IHF-A Weighted, at 1kHz) Dimensions: 8-1/8" x 2" x 10-5/8" Features Bridgeable 2/3/4 Channel Capability PWM MOSFET Power Supply Balanced Isolator Input Circuit Screw-Type Power/Ground Terminals Screw-Type Speaker Terminals RCA Inputs (4 Channel) Hi-Volt Input Level Control (400mV-4.5V) Speaker Level Inputs (4 Channel) Selectable Crossover: 80Hz, -18dB/oct. LPF or 80Hz, -12dB/oct. HPF (A,B Ch.) Bass Boost (60Hz, 0 to +12dB) Statia a fost folosita cam 6 luni in stare impecabila de functionare,prezinta mici zgarieturi. Pret 230 RON |
Re: De vanzare Statie Pioneer GM-X334
Update de pret 2 mil.
Cu respect |
1.8 mil
Pret nou Cu respect. |
sold! to me :D multumesc mult!
