Vand DLS CA22
Amplificator DLS CA22 - functioneaza perfect, a fost folosit pentru a amplifica o pereche de Tweetere DLS. Am cutia, factura si garantia din momentul achizitiei
Pret: 350 lei Contact: 0740.559.712 Number of channels 2 Amplifier class AB Mono bridge mode 4 ohm 200 W RMS Output power in 2 ohm 2 x 100 W RMS Output power in 4 ohm 2 x 60 W RMS Damping factor >100 S/N ratio, A-weighted >100 dB Frequency range 10 Hz - 35 kHz Input sensitivity 0,25 - 5 V Input impedance >10 kohm Input impedance, high level 100 ohm High pass filter 15-500 Hz Low pass filter 50 - 500 Hz Low level output Yes High level input with auto start Yes Power consumption (idle) 0,5 A Power consumption (max) 25 A Rec. power cable Minimum 5AWG / 16 mm2 Fuses 1 x 25 A Dimension (W x D x H) 250 x 212 x 67 mm / 9,84 x 8,35 x 2,63" Weight 2,7 kg / 5,95 lb |
Re: Vand DLS CA22
Vandut!
| All times are GMT +2. The time now is 18:59. |
