dezmembrez opel astra g y20dth an 2002,cod pompa 015
13 Attachment(s)
cod pompa injectie 015 350e + garantie comenzi volan volan piele spirala comenzi ceasuri albe pilot automat calculator de bord cui tractare trapa electrica 4 geamuri electrice magazie cd uri consola mahon clima jante aliaj pe 16'' + cauciucuri etc |
Re: dezmembrez opel astra g y20dth an 2002,cod pompa 015
dezmembrez astra g 1.2 z12xe, 1.6,2.0 benzina,1.7 y17dt, 2.0 y20dth diesel
usi,motoarele se dau fie complete fie dezechipate === A ===================================== aripi negre 50 ron/buc aripi albastre 90 ron/buc amortizoare fata/spate 50 ron/buc arcuri fata/spate 50 ron buc aeroterma 130 ron airbag sofer 150 ron air bag pasager 100 ron air bag scaune fata 100 ron /buc ansamblu stergatoare 130 ron alternator 1.2,1.4,1.6,2.0 benzina 120 ron alternator 2.0 diesel Y20dth 150 ron ambreiaj y20dth 100 ron ambreiaj z12xe 100 ron === B ===================================== buton avarie 30 ron brat stergator spate coupe/hatchback 50 ron bandouri coupe fata/spate 30 ron/buc bara fata cu gauri proiectoare 200 ron bara spate 230 ron bobina de inductie 1.2 z12xe 220 ron buton avarii 30 ron bloc lumini fara proiectoare 50 ron bascula st/dr 50 ron boxe fata coupe 50 ron/set boxe spate coupe 50 ron/set baie de ulei 1.2 benzina z12xe 130 ron baie de ulei 2.0 diesel y20dth 130 ron baie de ulei 2.0 benzina 136 cp an 99' 110 ron === C ===================================== capac ulei benzina diesel 25 ron calculator motor 1.2 z12xe an 2001 garantie 500 ron calculator motor 2.0 y20dth an 2001 300 ron calculator motor 1.6 x16xe 200 ron calculator motor 2.0 benzina 136 cp an 99' 200 ron carcasa filtru motorina y20dth 60 ron caroserie coupe stare impecabila cu acte 1200 ron cutiuta acte 30 ron capace oglinzi 30 ron/buc carcasa oglinda manuala 40 ron/buc carcasa filtru de aer 60 ron calculator 2/4 air bag-uri 60 ron/buc ceasuri bord normala benzina 100 ron caseta de directie benzina 400 ron caseta de directie diesel y20dth 500 ron catalizator y20dth 350 ron catalizator z12xe 300 ron carlig remorcare 300 ron capota 250 ron consola centrala 70 ron consola dintre scaune 70 ron comanda a/c 100 ron centuri fata 40 ron/buc cutie de viteze F18 de pe un 2.0 benzina 350 ron cutie de viteze F23 de pe un 2.0 diesel Y20DTH 550 ron cutie viteze de pe un 1.2 benzina Z12XE 500 ron compresor a/c 2.0 diesel y20dth 350 ron conducte apa,aer etc 20 ron/buc contact ,butuc portbagaj + butuc usa 150 ron clapeta acceleratie Z12xe,z14xe,z16xe 100 ron clapeta acceleratie 2.0 y20dth 120 ron calculator A/C benzina /diesel 120 ron covorase auto(mocheta,cauciuc,transparente) 40 ron/set chedere usi/portbagaj 30 ron/buc === D =================================== debitmetru z14xe,z16xe 2.0 benzina 100 ron debitmetru y20dth 120 ron === E ==================================== electromotor 1.2,1.4,1.6,2.0 benzina 100 ron electromotor 2.0 y20dth diesel 200 ron electroventilator apa 100 ron electroventilator A/c 100 ron etrieri fata/spate 4 prezoane 70 ron/buc etrieri fata/spate 5 prezoane benzina/diesel 70 ron/buc egr 1.2 z12xe 100 ron egr 2.0 y20dth (mecanic) 150 ron === F ======================================== far 100 ron === G ===================================== grila capota cu sigla opel 60 ron geamuri spate laterale coupe 70 ron geamuri fata laterale 70 ron geamuri laterale berlina,hatchback 70 ron goarne claxon 30 ron/buc === H ======================================= haion caravan/hatchback/coupe 300 ron === I ======================================= interior textil coupe impecabil 250 ron/set instalatie motor y20dth 100 ron instalatie motor z12xe 100 ron injectoare 1.2 z12xe 90 ron/set injectoare 1.4,1.6 z14xe,z16xe 90 ron/set injectoare 2.0 benzina 136cp an 99" 50 ron/set injectoare 2.0 y20dth diesel 300 ron/set === J ======================================= jante aliaj 4 prezoane 3buc 350 ron janta aliaj 130 ron/buc jante tabla 4 prezoane 4 buc 300 ron janta tabla 100 ron/buc === K ======================================= kit geamuri electrice fata coupe,hatchback 250 ron/set === L ====================================== lonjeroane 80 ron/buc === M ========================================= maneta semnalizare cu pilot automat 150 ron maneta semnalizare simpla 30 ron maneta stergatoare 30 ron maneta schimbator cu cabluri diesel y20dth 50 ron maneta schimbator cu tija benzina 50 ron mocheta portbagaj 50 ron motor 2.0 y20dth(an 2001,150.000km) 900 ron motor 1.2 z12xe (an 2001,130.000km) 800 ron macarale +instalatie geamuri electrice fata 250 ron modul inchidere centralizata 70 ron/buc motoras stergator luneta 70 ron motoras faruri 20 ron/buc motoras vas lichid parbriz 30 ron === O ======================================== oglinda centrala 40 ron oglinzi laterale manuale 30 ron === P ========================================= prag plastic coupe st/dr 50 ron/buc planetara de pe un 1.2 z12xe 150 ron/buc planetara de pe un 2.0 benzina 136 cp 150 ron/buc planetara de pe un 2.0 diesel y20dth 101 cp 150 ron/buc pedala acceleratie electronica 1.2,1.4,1.6 130 ron/buc pompa benzina z16xe,z12xe 100 ron plansa bord 550 ron punte spate(dezechipata) 330 ron parbriz 210 ron plafon coupe(capitonaj) 60 ron pretensionere centuri 60 ron/set pompa servodirectie benzina fara butoias 280 ron pompa servodirectie diesel 300 ron proiector st/dr 60 ron pompa vacuum y20dth 100 ron === R ========================================= radiator apa 170 ron radiator A/C 170 ron ranforsare bara fata 50 ron rulment cu abs fata 4 prezoane 140 ron rulment cu abs fata 5 prezoane 140 ron rulment cu abs spate 4 prezoane(disc) 140 ron rulment cu abs spate 5 prezoane (disc) 140 ron rulment cu abs spate 4 prezoane (tambur) 140 ron rezervor benzina 100 ron rezervor diesel 100 ron === s ========================================= senzori motor 1.2,1.4,1.6,2.0 benzina de la--- 40 ron/buc senzori motor y20dth diesel de la--- 40 ron/buc supape vacuum 3 buc y20dth 100 ron/buc scrumiera fata 30 ron suport motor 220 ron stopuri coupe/hatchback 80 ron suport 5 cd-uri 100 ron semnale aripa 10 ron/buc spirala comenzi volan 60 ron === T =========================================== traversa faruri 50 ron turbina y20 dth 400 ron traversa bord 50 ron tampoane motor 60 ron termocupla radiator A/C 1.2,1.4,1.6,2.0 50 ron triple coupe/hatchback 80 ron torpedou cu bratele intregi 80 ron/negru T.I.D. 50 ron termostat 1.2,1.4,1.6,2.0 benzina 60 ron termostat 2.0 diesel y20dth 60 ron === U ======================================== usi coupe (albastre,negre rosii) echipate 300 ron usi coupe (albastre,negre rosii) dezechipatte 100 ron usi hatchback fata spate dezechipate 100 ron usita rezervor(gri,verde,albastra,neagra) 40 ron === V ========================================== vacuum egr vas lichid parbriz 40 ron vas expansiune 40 ron volan piele+comenzi 100 ron volan cauciuc fara comenzi 50 ron volanta y20dth 150 ron volanta z12xe 150 ron pentru a gasi mai usor in lista piesa dorita apasat tasta Ctrl + F apoi tasta Enter pentru mai multe detalii si informatii despre piesele care nu apar in lista sunati 0765487272---0721579402 |
un pret la calculatorul de bord+mid+manete..tot ce trebuie pentru a fi montat..la masina mea..+pilot automat... inelele la ceasuri le dai separat? |
ma intereseaza turbina pentru 2.0
