vand cd mp3 SONY 3900 bt
vand cd mp3 SONY 3900 bt,500 LEI.0722133390
Radio CD/MP3 player cu Bluetooth si USB • Radio CD/MP3 • Bluetooth 2.0 • Tuner radio cu RDS-EON • BTM (Best Tuning Memory) • Memorii posturi radio - 16 in FM, 6 in MW si 6 in LW • Formate suportate la redarea de pe CD - CD-Audio, CD-R/RW, MP3(cu ID3 Tag), WMA(cu WMA Tag), CD-Text • Convertor digital-analog pe 24 de biti • Raspuns in frecventa 10-20000Hz (+/- 1dB) • Raport semnal/zgomot - 120dB • Functii Repeat/Shuffle • Amplificare interna cu tranzistori MOSFET • Putere nominala 4x27W (4ohmi) • Putere maxima 4x52W (1kHz, 4ohmi) • Egalizator pe 3 cai EQ3 • Corectii de ton pe 3 cai - Low/Mid/High • Functie Loudness • Port USB pe panoul frontal • Conectivitate Ipod posibila direct prin intermediul conectorului USB frontal • Conectivitate Bluetooth • Bluetooth Audio Streaming - permite redarea prin tehnologie Bluetooth, prin sistemul audio al masinii, a fisierelor MP3 stocate in memoria interna a telefoanelor compatibile A2DP • Bluetooth Handsfree - permite folosirea in mod "maini libere" a telefonului mobil in masina • Iesiri pre-out (RCA) de 4V - 3 perechi - Front, Rear si Sub • Filtru LPF si HPF integrate • Control volum subwoofer • Intrare auxiliara (Aux-In) pe panoul frontal - jack 3.5mm • Mecanica CD - Drive-S • Afisaj FL LCD • Dimmer • Iluminare taste - albastru • Ceas • Panou frontal detasabil • Telecomanda tip card inclusa • Compatibil telecomanda de volan RM-X4S |
| All times are GMT +2. The time now is 14:00. |
