-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   Amplificator auto DLS CA41 (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/377063-amplificator-auto-dls-ca41.html)
florica1477 03-06-13 19:54
Stare noua , nemontata , carte tehnica . cabluri .
amplificator cu patru canale
clasa AB
putere la 4 ohm 4 x 70 W
putere la 2 ohm 4 x 125 W
putere in punte la 4 ohm 2 x 200 W
raspuns in frecventa: 10 Hz - 35 kHz
damping factor > 100
s/n ratio, A-weighted > 100 dB
filtre canalele AB - HP: 15-500 Hz. LP: 50-500 Hz / 0,5 - 5 kHz (x10)
filtre canalele CD - HP: 15-500 Hz / 150 Hz - 5 kHz (x10)
grand bass filter 0-18 dB @ 25-80 Hz
dimensiuni 70 x 372 mm x 268 mm
http://dls.se/en/car/prod.html?produkt=en_890
CA 41 is a powerful amplifier with power output of 4 x 70 Watts. With a mono bridge-connection, it puts out all of 200 Watts.
- Built-in/switchable low pass and high pass filters.
- Bass boost 25 Hz - 80 Hz 0-18 dB.
- Built-in protection circuits shut down the amplifier in the event of overloads.
- Hi level input with Auto start
Use it for a front system and a subwoofer.
- High level input with auto start.
- RMS output power @ 13,8 V, 20Hz - 20 kHz
pret :750 ron negociabil
0722577005
