Vand aerografe diverse
1.Aerograf profesional 200ron
Twin action for greater control, a precision needle and regulation of air for fine detailed work.Excellent air brush system for precise and accurate work. Specifications: Feed Type: Gravity Nozzle Dia: 1x 0.2mm & 1x0.5mm Needle Dia: 1x 0.2mm & 1x0.5mm Cup Capacity: 1x7cc Spanner: 1 pc Air Hose: 1x 1.8m (6ft) Regulator: 1x G1/4-1/8 Working Pressure: 15-50 PSI 2.Aerograf semi-profesional 60ron Single-action airbrush set for easy painting of models. Low maintenance, and ease of use make this a good choice for the first time painter. Specifications: Spray pattern adjusts from l/4" to 5" for maximum versatility. Includes fine head airbrush, 5ft. vinyl hose, 2oz. Jar, with cover,attached 3/4oz. jar, propel regulatorand adaptor (I/4" air hose from the compressor to the smaller air brush hose.) Standard Nozzle Dia.: 0.8mm Operating Pressure: 15-50psi Contact:0724885194 |
Re: Vand aerografe diverse
Pai le vinzi mai scump decat costa ele noi!
Ia priveste aici: iti pare faimiliar? http://www.picturaonline.ro/aerograf...une-ab130.html sau acilea: http://www.colorit.ro/products/aerograf-ab130.html si aia trebuie sa mai plateasca si TVA, si multe alte impozite.... Unde mai e afacerea?? |
salut mai este valabil
Afacerea e ca de la ei nu primesti nimic din ce vezi la mine in pachet! duzele alea nu se gasesc nicaieri in tara. ei iti dau jucaria in mana si gata. |
salut ai primit
Am primit si le-am si dat . ideea e ca trebuie sa ma suni sa faci o rezervare.Ms
