Statie Auto Beyma.
statia este sigilata .Model 1504 power street series.
Re: Statie Auto Beyma.
un pret pt ea ai fixat?ms.
nu stiu cat sa cer.fa-mi un pret corect pentru amandoi.merci.
pai nu ai trecut si tu puterile?
sa stim si noi ce e cu ea...... si zi si tu un pret |
da scuze::oops:
Product Description: Street Power Series 4-Channel Amplifier RMS Power Rating: 4 ohms: 75 watts x 4 chan. 2 ohms: 120 watts x 4 chan. Bright Decorative Neon Blue Illumination High Pass and Low Pass Crossover Advanced Thermal and Overload Protection Circuitry Optimized muting circuitry eliminates turn-on and turn-offs noises Bridged RMS: 240 watts x 2 chan. @ 4 ohms MOSFET Power Supply RCA Terminals 4 Gauge Power/Ground Leads Frequency Response: 20 - 20kHz Signal to Noise Ratio: 100 dB Gold Plated power and speakers terminals Gold Plated front and rear signal input Jacks Low ESR/High Voltage Rail Support High Effeciency Extruded Aluminum Alloy Heatsink Dimensions: 16.55"L x 9"W x 2.25H Amplifier Specifications: Amplifier Class N/A Number of Channels 4 RMS Power (4 ohms) 75 watts x 4 chan. RMS Power (2 ohms) 120 watts x 4 chan. RMS Power (1 ohm) Not stable Bridged RMS Power 240 watts x 2 chan. @ 4 ohms Peak Power Output 600 watts Minimum Impedance Unbridged 2 ohms Minimum Impedance Bridged 4 ohms THD at Rated RMS Power .02%% Speaker Level Inputs N/A Amp Preamp Outputs N/A Built-in Crossover Yes - LP/HP High-Pass Crossover Frequency 12 - 200Hz Low-Pass Crossover Frequency 40 - 200Hz Subsonic Filter Signal-to-Noise Ratio 100 dB Channel Separation N/A Bass Boost 0 - 18 dB Bass/Gain Remote No Fan Cooled N/A Fuse Rating 30A x 2 :arrow: PRET 550 ron!!! in afara am vazut ca se vinde cu 400-500 euro! |
ai un nr de telefon?
YM geo_pc2002 sau 0743.639.720
up . valabil
up .nu vrea nimeni statie?
| All times are GMT +2. The time now is 13:00. |
