Vand Ground Zero 6900P
Vand GZRF 6900P In stare excelenta.
Detalii producator: ModelGZRF 6900P Type2 Wege Koaxial / 2 Way Coax Diameter of midwoofer or midrange150 x 230 mm / 6" x 9" Mounting diameter of midwoofer or midrange153 x 216 mm / 6.02" x 8.5" Mounting depth of midwoofer or midrange85 mm / 3.35" Voice coil of midwoofer or midrange50 mm / 2" Cone of midwoofer or midrangeBeschichtetes Papier / Coated paper Dustcap / Phaseplug of midwoofer or midrange- Basket of midwoofer or midrangeStahl / Steel Magnet of midwoofer or midrangeFerrit Diameter of tweeter- Mounting diameter of tweeter- Mounting depth of tweeter- Voice coil of tweeter50 mm / 2" & 13 mm / 0.51" Cone of tweeterMylar Housing of tweeterABS Magnet of tweeterFerrit & Neodym Power handling WRMS250 W Power handling W peak400 W Impedance4 Ohm SPL92,7 dB Frequency response40 - 20000 Hz Pretul este de 250 RON. http://www.ground-zero-audio.com/com...c2939908cf.jpg http://www.************/produse/Difu...ve/GZRF_6900P/ |
| All times are GMT +2. The time now is 11:02. |
