Dino...adevarul
from CAR AND DRIVER MAGAZINE
BY AARON ROBINSON PHOTOGRAPHY BY DAVID DEWHURST May 2004 ********** is like good luck. It can't be seen, touched, or tasted, but you know when the inventory is low. How much do you have? Go measure it. The best place to put your luck to the yardstick is in Las Vegas. The best place to measure your ********** is on a dynamometer. In both cases, results have been known to vary. Turns out that different ********** dynamometers will spit out different results on the same car depending on their design and how carefully the tester manages the variables. When ambient air temperature and pressure were all that yesterday's carburetors cared about, factoring in the variables was easy. But modern cars are gradually becoming too smart for what was once a simple test. Engines trying to squeeze out more ********** are run by watchful computers with better sensors that are able to differentiate between speeding down a freeway with a cooling headwind and spinning the dyno drums in a stuffy room. The technology of today's cars needs to be factored into your readings along with variations from dyno type to dyno type, or your ********** numbers may be hazy, too. Recall that ********** is a unit measuring the rate at which an engine performs work. By current industry standards, one ********** equals 550 pounds lifted at the rate of one foot every second. Automakers figure a car's oomph by hitching the engine to a machine that puts a controlled load generated by an electric or hydraulic brake on the flywheel. They plumb the intake and coolant to external fixtures that simulate on-road airflow and then run the engine from idle to redline. The engine dyno measures torque at the crankshaft using a variety of means and then uses a math formula—torque times rpm divided by 5252 (a sort of gearhead's constant, derived by dividing . . . oh, never mind). ********** comes after the equal sign. Thousands of hours of testing produce a peak ********** number that prints in the dealer's brochure. For the rest of us, rather than unbolt the engine and rent a multimillion-dollar dyno room, it's much easier to simply drive the whole car onto a chassis dyno that measures ********** where the tires meet the tarmac. Throughout the U.S. are shops with such machines, some even capable of handling four-wheel-drive cars. Ordinary citizens pay anywhere from $35 to $100 to run the car up to redline three or four times, the tires turning rollers monitored by the dyno's computer. Eventually, the computer spits out a ********** graph that you can take to your next bar-stool drag race. But before you pop the clutch on your tongue, consider that a chassis dyno doesn't measure ********** at the flywheel but at the tires after various driveline losses have subtracted their drag. Friction from rubbing gear faces, inertia from heavy shafts, and the stirring of oatmeal-like gear lube all reduce the advertised ********** reaching the tires and, hence, the dyno. "There's no really accurate way to get engine ********** from a chassis dyno," says Matt Harwood, marketing coordinator for Mustang Dynamometer, a major supplier of chassis dynos in Twinsburg, Ohio. Some tuners use the so-called 15/20 rule, which assumes a 15-percent driveline loss for manual transmissions and 20 percent for automatics. But, says Harwood, "I've seen losses as high as 35 percent." So unless it's printed in the brochure or was measured on a true engine dyno or by a tuner with tons of experience with your particular brand of car, any flywheel ********** number quoted by a hot rodder under the shade tree is most likely just a calculated guess. More important, did your car run on the dyno as it would on the street? If it's the latest model, chances are good it may not have, says BMW tuning wizard Steve Dinan. An afternoon spent at his Bavarian speed emporium in Morgan Hill, California, convinced us that cars are gradually becoming too computerized for the simple dyno test. Dinan's cars are wired with a battery of sensors that report when the airflow over the bumper is too little, when the inlet air is too hot, and when the water temperatures in the block and radiator are too close together (most turbocharged and supercharged cars also "know" when their intercoolers aren't cooling enough). The computer reacts by backing off the spark and turning up the richness—and as a result, turning down the power—to prevent catastrophic engine meltdowns. To prove his point, Dinan bolts to his Dynopack one of his 2003 Dinan M5s, heavily tweaked to make a claimed 470 ********** at the crank (he expects about 415 at the wheels). With the hood closed and no external fan blowing air into the radiator, the car wheezes out just 334 ********** at the wheels. An LCD data logger on the dashboard reveals the air-fuel ratio from the engine computer. Approaching redline, the BMW's computer richens the mixture all the way to 9.5:1 as the underhood temperatures soar. That's one thick mix, practically charcoal briquettes blowing out of the tailpipe. But then, with the M5 running in fifth gear (the 1:1 gear ratio with the least friction, preferred by dyno testers), the computer expects 159 mph worth of cooling wind blast around the ********** peak. It's getting nothing, and it knows. Now Dinan opens the hood and turns on a small Home Depot shop fan blowing about 10 mph worth of air. The M5 is allowed to shed some excess heat and then run again. This time the computer finds another 37 **********, or 371. Things are looking up, but the M5's output is still nowhere near Dinan's expected number of 415. "I can't claim something I can't measure," says Dinan, so the crew then wheels out the big gun: a $7000 electric fan that looks like it should be hanging on the wing of a Boeing 737. It blasts 38,000 cubic feet per minute of air at 75 mph down a narrow duct, right into the M5's radiator. The fan roars, the M5 howls, the computer twinkles, and the graph paper ticka-ticks out of the printer. It says 411.4 **********, the best run of the day. "I'd pick up four or five more ********** if I came back tomorrow morning and ran it at 70-degree room temperature," says Dinan. The room is currently 81 degrees. "Basically, what ********** would you like? I can give you anything from 330 to 420 with the same car," Dinan says. "Blowing air with a fan isn't the same as creating a bow-pressure effect over the whole front of the car. BMW can simulate that because it has billions to spend on wind tunnels. We don't, but we can come close by spending $250,000 to $300,000 on a climate-controlled room." That's Dinan's next step. It's a huge expense for a boutique parts-maker, but BMWs aren't getting any stupider. The trend says the cars rolling into a tuner's shop will have more and smarter sensors with each passing model year. BMW may be at the leading edge of electronic engine controls right now, but the rest of the industry is sure to follow. When it does, the "brag-ability" of dyno numbers will get even more dubious as dyno printouts become merely a reflection of what a particular car does on a particular dyno under a particular set of conditions. What happens on the street could be another matter altogether. As in Vegas, sure bets are in short supply when you measure **********. Unde sunt * * * * * ar tebuia sa fie hor-se-po-wer, numai ca ... forumul scoate :P |
Re: Dino...adevarul
dupa titlu am crezut ca e vb de vreo emisiune de pe animal planet in care se trateaza adevarul despre dinozauri.
Re: Dino...adevarul
Intentionat am dat titlul.
Parerea mea este ca aparatul asta nu poate arata cuplul original, numai ceva ce este in jurul acesteia. Mai mult, roata este ca o volanta si aceasta functioneaza la fel, deci gurba fecuta pe calculator este mult mai frumoasta dacat cum ar fi original, adica ceace este masurat pa motor(volanta). Mai este si Dynopack, care nu foloseste roata ci vine direct pe axa...macar problema de inertia totii este scoasa, dar costa dublu... Ideal ar fi, sa cumparam un Dynopack si transformand in masurarea motorului propriu zis...dar costa mult :( Din pacata trebue 2 aparate, una este pentru a regla (asta e bine sa fie cu ulei, hidraulic) cealalta pentru putere maxima (preferabil una cu balansa si electromotor...costa enomr dar neregulitatile mici nu poate fi sesizate)!!! Este mult de zis, cei priceputi in tema, si nu vor afacere din asta (fiindca multi asta fac si omului ii pare foarte bine ca perge si lauda la prieteni cu fituica primita...) zic ca cel mai relevant este sa masori acceleratie (timpul) la 400 si 1000 de matri, asta faci 3-5 ori si vezi cum sta masina. Ori cum, la uram urmei asa te intereseaza nu cai... |
Re: Dino...adevarul
eu pe mustang dyno am scos cu evoul 680 la roti la 6700 rpm si la 20psi fara nos cu nos cred ca scot pe la vre-o 800 iar pe flash dyno am scos 730 dar flash da erori mari la peste 300hp deci nu am incredere in el in doua teste pe mustang dyno am scoc 680 pe 101 octane gas
Re: Dino...adevarul
Jur de 700cai din 2.0 turbo este cam mult...ce ai facut cu saracul?
Dar cu trensmisia ai facut ceva? |
Re: Dino...adevarul
are transmisie de pe un model wrc de evo 7 are twin turbo kit Garrett ,nu mai e 2.0l demult avea 2.4l stroker kit pistoane cosworth segmenti si cuzineti de performanta pompa de ulei cu debit marit radiator de ulei suplimentar diferential spate fatza de la HKS supape din titan , am bagat in masina aia peste 40k in modificari :)
Re: Dino...adevarul
pai daca ai pus toate asta in masina nu e mult 40k...
Dar cred ca ai atins limitele...cel putin pentru srada... |
Re: Dino...adevarul
asa cred si eu dar din pacate acum masina e zob in august am avut un accident din cauza cauciucurilor michelin pilot sport drag radials , am fost despagubit de asigurare pana la ultimul cent si acum astept sa apara evo 10 sa-mi fac de cap cu el :P si pana una alta am un audi s4 un jeg dupa parerea mea
Re: Dino...adevarul
O fise dyno ai?
Re: Dino...adevarul
o am da-i in az in storage cand ajung acolo peste vre-o 3 saptamani i trag un scan
Re: Dino...adevarul
Mar relevant e 400 si 1000m accelerarea... |
Re: Dino...adevarul
Naso ce sa intamplat...macar ai scapat!!! Si dim masina ce a mai ramas? |
Re: Dino...adevarul
pai hai sa vezi pozele ce mi le-o dat asigurarea sa vad din ce am iesit, de scapat am scapt cu 2 saptamani de spital si multe foarte multe vanatai.
Re: Dino...adevarul
Nasol.Cum ai reusit s-o busesti asa?
Re: Dino...adevarul
mi-o explodat cauciucu dreapta fatza so rupt si o blocat roata si mo aruncat intr-un zid cauciu pe care il instalasem cu 2 ore inainte michelin pilot sport drag radial rated 190mph si la 170 o cedat acuma sunt in proces cu compania de la care le-am cumparat am raportu politiei raportu companieie de asigurari si plus declaratia soferului de pe tow trucku care mi-o dus-o la impound. Leam cerut 2 mil si nu ma las pana nu-i iau avocati pe care mi io recomandat politistu ce mo scos din masina mi-au spus ca am cerut prea putin dar ca am sa-i vad pana la urma .
| All times are GMT +2. The time now is 00:27. |
