Vand un set de componente DD Hi-end
Vand un set de componente DD , noi nefolosite, ofer proba.
Pret 2500 ron negociabil si discutabil sau.......... schimb cu bani :D DD AT-28 The DD-AT28 is a wide-band tweeter with a 28mm coil diameter. It uses two rear chambers, one behind the voice coil and a second milled aluminum chamber behind the motor. Shorting rings are used in the motor to flatten the impedance curve and wick away heat from the coil windings. 150 W RMS Frequency Response 1500 Hz to 30 kHz FS 800 Hz Nominal Impedance 4 Ohm DD W6.5 The DDW6.5 mid-bass/mid-range driver was designed to deliver the widest possible bandwidth while providing a fast transient response with high levels of long term power handling. The cone is a composite blend of Kevlar fiber, carbon fiber and a very stiff and lightweight resin. This combination has an excellent strength to weight ratio that is light enough to react quickly to complex signals yet rigid enough not to flex when subjected to extreme power levels. The surround is a well dampened rubber half roll. The motor structure incorporates long magnetic field technology which ensures precise control over cone excursions and efficiently dissipates heat from the voice coil. The voice coil former is made from black anodized aluminum layered with arimid fiber and wound with the wire capable of enduring temperatures to 500 degrees F. The dual flat spider suspension is made from synthetic materials to give the smoothest response and long lasting durability. The lead wires are laminated into the layers and run across opposite sides to even out weight over the moving system. The leads are terminated in 10ga. copper wire for the most efficient electrical transfer. The DDW6.5 makes an excellent subwoofer in space limited systems and great for high powered midbass applications. SPECIFICATIONS Power Handling RMS/Peak 150/400 Voice Coil Diameter 1.5" Magnet Weight 28 oz Suspension travel 25mm Nominal Impedance 4.0 Ohm DC Resistance 3.1 Ohm |
Re: Vand un set de componente DD Hi-end
Faceti o oferta si discutam ! Pret la liber, cine face o oferta de bun simt le ia! Accept si unele schimburi !
Nu are nimeni curaj sa faca o oferta? ....sau nu va plac difuzoarele ca sunt murdare cu literele alea rosii :lol::lol: ??
1.700 ron !
| All times are GMT +2. The time now is 19:21. |
