vand amplificator 1004
Functioneaza perfec, nu are nicio problema, il am de nou! 072074322 pret 450 ron GTO 1004 Specifications
Output Power: 100W RMS x 4 channels @ 4 ohms; ≤1% THD + N (14.4V supply) 150W RMS x 4 channels @ 2 ohms; ≤1% THD + N 320W RMS x 2 channel (bridged) @ 4 ohms; ≤1% THD + N Signal-to-noise ratio: 85dBA (reference 1W into 4 ohms) 104dBA (reference rated power into 4 ohms) Dynamic power: 180W @ 2 ohms Frequency response: 10Hz – 100kHz (–3dB) THD+N 1KHz LPF=22KHz ≤0.05% (rated power @ 4 ohms) Channel Separation ≥45db (full rated power) Input Impedance >20K ohms Maximum input signal: 6.0V Maximum sensitivity: 100mV Hi-Pass, Low Pass X-over Limits 32Hz – 320Hz ±20% Bass Boost @ 50Hz 0-12dB DC Offset <30mV Output regulation: .03dB @ 4 ohms Idle Current @ 4 ohms 1.5A Max Current Draw <70A @ 2 ohms both channels driven Remote Operating Voltages ON 5V OFF 4V Turn-on delay time 2-3 sec Circuit Protection Temperature (85±5C), Short circuit, Operating voltage range (8-16V) Dimensions: 18 9/16 x 10 3/8 x 2 1/8” (470 x 263 x 53mm) |
Re: vand amplificator 1004
[QUOTE=mihay10;5429785]Functioneaza perfect, nu are nicio problema, il am de nou! 072074322 pret 400 ron GTO 1004 Specifications
Output Power: 100W RMS x 4 channels @ 4 ohms; ≤1% THD + N (14.4V supply) 150W RMS x 4 channels @ 2 ohms; ≤1% THD + N 320W RMS x 2 channel (bridged) @ 4 ohms; ≤1% THD + N Signal-to-noise ratio: 85dBA (reference 1W into 4 ohms) 104dBA (reference rated power into 4 ohms) Frequency response: 10Hz – 100kHz (–3dB) THD+N 1KHz LPF=22KHz ≤0.05% (rated power @ 4 ohms) Channel Separation ≥45db (full rated power) Input Impedance >20K ohms Maximum input signal: 6.0V Maximum sensitivity: 100mV Hi-Pass, Low Pass X-over Limits 32Hz – 320Hz ±20% Bass Boost @ 50Hz 0-12dB DC Offset <30mV Output regulation: .03dB @ 4 ohms Idle Current @ 4 ohms 1.5A Turn-on delay time 2-3 sec Circuit Protection Temperature (85±5C), Short circuit, Operating voltage range (8-16V) Dimensions: 18 9/16 x 10 3/8 x 2 1/8” (470 x 263 x 53mm) |
| All times are GMT +2. The time now is 18:00. |
