Vand stand alone Haltech E6X
vand stand alone haltech E6X pe 4 canale. map senzor pana la 1.5 bar.
nu are mufa. costa 30$ pe ebay. Hatech E6X ECU and loom - with built in 1.5 bar /22 psi MAP sensor The HALTECH is a powerful “real-time” programmable fuel injection and ignition computer designed to control most ignition type engines. Whether 1-6, 8, 10 or 12 cylinders, 1-2 rotors, naturally aspirated, turbocharged or supercharged, the HALTECH can control it. Up to 4 fuel and 4 ignition channels (internal toggle) 4 dedicated PWM outputs 1 auxiliary input 1 auxiliary output (tacho output) Dedicated closed loop idle control Dedicated closed loop o2 correction 8 injector drivers as standard equipment An internal barometric pressure sensor New RA8 reluctor adaptor Rev Limiter Deceleration fuel cut Datalogging to laptop Flatshift Dual Mapping High boost software (up to 65 pounds with optional MAP sensor) pret: 500E tel: 0762039099 |
| All times are GMT +2. The time now is 20:40. |
