Vand amplificator Alpine MRP-M2000
Alpine MRP-M2000
V-Power Series Class D Monoblock Car Amplifier RMS Power Rating: 4 ohms: 1500 watts x 1 chan. 2 ohms: 2000 watts x 1 chan. Max power output: 4000 watts x 1 chan. approx. Pulse width modulated (PWM) MOSFET Power supply Blue LED power indicators Tuned Bass EQ (0-12 dB bass boost at 50 Hz) STAR Board circuitry (minimizes internal noise and prevents ground interference) Continuously adjustable gain control Speaker level inputs and flush mount controls make installation a breeze Dual sided glass epoxy PC Board Thermal management control Heat sinks along with the thermal processor monitor the amplifiers temperature Gold-plated RCA level inputs Gold-plated screw terminals Adjustable low-pass filter (50-200Hz, 24 dB/octave) Subsonic Filter (24 dB at 15 Hz) CEA-2006 compliant amplifier Frequency response: 20-200 Hz 0/1-gauge power and ground wiring is required for installation. http://postimage.org/image/9jp6626sp/ poza reala Stare impecabila Pret 1400 RON |
Re: Vand amplificator Alpine MRP-M2000
UPPPP
1300 RON |
1200 ron
UPPPPPPPPPPPPPPPPPPPP last uPPPPPPPPPPPPPPPP |
1100 ron
Salut, te-ar interesa cumva un schimb cu un DLS CA31 + diferenta?
| All times are GMT +2. The time now is 03:33. |
