-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   Amplificator auto Peiying Alien PY-A4E76R (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/362247-amplificator-auto-peiying-alien-py-a4e76r.html)
Dj_Dog 24-02-13 15:56
CARACTERISTICI GENERALE
Producator Peiying
Clasa amplificator: AB
Putere totala (W): 2000
Putere RMS (W): 120
Numar canale: 4
Frecventa de raspuns (Hz): 20
Lowpass (Hz): 50Hz - 500Hz
Highpass (Hz): 50Hz - 1000Hz
Informatii suplimentare: RMS Power (4 ohms): 120W
RMS Power (4 ohms) chanels: x 4
RMS Power (2 ohms): 180W
RMS Power (2 ohms) chanels: x 4
Bridged RMS Power: 300W
Bridged RMS Power chanel: x 2
Minimum Impedance Unbridged: 2 Ohm
Minimum Impedance Bridged: 2 Ohm
Frequency response: 20Hz
Impedance imput: 15k Ohm
Fan Cooled: No
Signal to Noise Ratio: 90dB
Channel Separation: 50dB
THD: 0.08%
IMD: 0.08%
Remote bass boost control: 0.2V - +6V
High-Pass filter: 50Hz - 1000Hz
Bass Boost: 0dB - +18dB
Low-Pass filter: 50Hz - 500Hz
Fuse Rating: 30Ax3
Depth: 490mm
Height: 56mm
Width: 250mm
Dimensiuni (L x l x i mm): 250 x 490 x 56
Greutate (Kg): 5.8
Amplificatorul a fost folosit foarte putin, este perfect functional.
Au fost schimbate mufele de la intrare cu unele metalice si mult mai de calitate (cele originale erau din plastic si s-au rupt cand am scos mufele rca). NU ARE ALTA INTERVENTIE !!!
Este dotat cu 16 finali toshiba de 100W bucata!!!!
Detin telecomanda si conectorul pt intrearea Hi-Level (sunt noi noute nefolosite)
Pret 400 lei!!!
brinco218 26-02-13 15:34
Re: Amplificator auto Peiying Alien PY-A4E76R
Ai cumva si cabluri rca + alimentari la ea ?
Dj_Dog 26-02-13 17:30
am si cabluri separat, am un kit de cabluri sigilat de 50mm2
uite aici un filmulet cu statia in functiune https://www.youtube.com/watch?v=SFopt7bxXd0
poze cu kitul de cabluri http://dl.dropbox.com/u/60505897/poze%20kit%2050.rar
Dj_Dog 04-03-13 17:57
amplificatorul se poate da si la pachet cu un set de cabluri de 50mm2 la pretul de 500 lei!!
Dj_Dog 20-03-13 19:45
s-a dat
multumesc pt gazduire!!!
