Router,modem huawei smartax mt 882
General Specifications
Standards ITU G.992.1 (G.dmt), ITU G.992.2 (G.lite), ITU G.994.1 (G.hs), ANSI T1.413 Issue # 2, ITU-T G.992.5 (ADSL2+), ITU-T G.992.5 Annex L (G.lite) Data Transmission Rate ADSL: Downstream up to 8 Mbps, Upstream up to 896 Kbps ADSL2+: Downstream rate of 26 Mbps, upstream rate of 1M bps G.992.5 Annex L: Max. transmission distance of 6.5 kilometers External Interface WAN: One RJ-11 port for ADSL line connection LAN: One USB port for USB cable connection One RJ-45 port for 10/100 Base-T Ethernet connection Features Supporting 1483B bridging and routing function Supporting DHCP server, NAT/NAPT , PAP/CHAP, IP Filter, Firewall, protocol block Built-in PPPOE/PPPOA dialing Physical and Environmental Specifications Power Supply AC: 90~240V, power adapter: 9 V AC 1A Power Consumption < 9W Operating Temperature 0??? - 40??? ( 32 - 104°F) Humidity 5% - 95% (non-condensing) Dimensions 135mm x 110mmx 28mm Net Weight 190g LED Indicators Power, ADSL Link , ADSL ACT, LAN Link ,USB toate accesoriile incluse inclusiv cablul usb,gata de conectare. pret,40 lei 0765451018/pm |
Re: Router,modem huawei smartax mt 882
up lei 40
up 30 lei.
up 30 lei.
up 25 lei
up 25 lei
25 lei
20 lei
20 lei
Numai cablul usb de la modemul adsl am vazut pe okazii 15 lei ;)
20 lei
20 lei
20 lei
20 lei
20 lei
| All times are GMT +2. The time now is 10:34. |
