VAND DVD NOU NAVI Bluetooth, TOUCH, full conectivity la cutie, cu accesorii
Jensen vm9022 NOU, LA CUTIE, NEMONTAT, NEFOLOSIT:
Unitate multimedia 2DIN DVD, NAVI, Touchscreen, Pro-Logic 5.1, SOUND TIME CORRECTION, bluetooth, telecomanda, conectivitate cu toate mediile de stocare si portabile posibile, conectivitate real-time cu APPLE, picture in picture, suporta camere video, iesiri auxiliare, modulele sunt incluse, ca si toate accesoriile INCLUSE LA PACHET; DOAR ACCESORIILE, DACA E SA CAUTATI PRETURI, DEPASESC 150 EURO CA VALOARE. PREAMPLIFICARE 6 canale, respectiv 5.1 PRO-LOGIC !!!!!!!!!!!! tot ce poate sti un player, acesta stie sa faca: General Features Product Overview: The Jensen VM9022 double-DIN multimedia unit includes a DVD/CD receiver with a 6.5" motorized monitor. It has an integrated SD Memory Card slot behind the front panel, comes with a MediaLink auxiliary A/V and iPod input module, has dual zone capability, and built-in Bluetooth hardware. Motorized 6.5" TFT LCD Monitor: The VM9022 features a motorized 6.5" TFT Active Matrix, 16:9 wide-angle touchscreen display with an adjustable viewing angle. The resolution of the display is 1200 x 234 for a total of 280,800 pixels. The screen has a 120° horizontal viewing angle (60° left or right), and a 95° vertical viewing angle (40° up and 55° down). Menus appear on screen for making function choices, audio adjustments, and setting up the system. Display Angle Adjustment: You can adjust the display's angle for better visibility. Starting flat, the display tilts upward and has 16 tilt positions. Auto Open/Close: The display automatically tilts to the last viewing position when the ignition is turned on and closes (flat) when the ignition is turned off. Display Adjustment: You can adjust the display's brightness and contrast. Aspect Ratio: 16:9 video sources are displayed full screen. There are two options for 4:3 sources: •Cinema: stretches picture horizontally to fill the entire width of the screen, distorting the picture slightly but retaining full image height •Normal: display with black bars on either side Bluetooth: The VM9022 has Bluetooth hardware built in to integrate with Bluetooth enabled cellular phones. Bluetooth is a two-way wireless communication system allowing you to make and receive cell phone calls. SD Memory Card: The VM9022 is equipped with a slot that will accommodate SD Memory Cards with MP3 or WMA files. MediaLink Auxiliary Input: The unit includes the MediaLink auxiliary input module for connecting a variety of external devices; VCR, DVD player, portable MP3 player, etc. The module has an attached 4' A/V cable which plugs directly into the back of the head unit. The module has a composite video input, stereo RCA and 3.5mm mini-jack audio inputs, a USB input, and an iPod input for use with the included jLink iPod cable. It can be mounted under dash or in a location convenient for plugging in auxiliary devices using the supplied screws. Electronic Skip Protection: This unit is equipped with 2 MB high-speed buffer for skip resistant playback. Equalizer: The seven band EQ has seven preset curves and one user programmable setting. User adjustments are +/-12 at 80, 250, 600, 1k, 4k, 10k, and 16kHz and the seven factory presets are Acoustic, Urban, Rave, Latin, Dance, Hip Hop, and Rock. Channel Level: The volume level of each channel, front left, front right, center, rear left, rear right, and subwoofer is independently adjustable. Subwoofer: The single 4 volt RMS RCA subwoofer output's low-pass filter frequency can be set to 50, 80, 100, 120, or 150Hz and the subwoofer's phase can be set to 0 or 180 degrees. MP3/WMA Playback: The VM9022 can play MP3 and WMA files recorded on CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, or DVD+RW discs and SD Memory cards. The files must be recorded in ISO 9660 or Joliet formats, the recommended bit rate is 128 kbps and sampling frequency is 48 kHz. Dual Zone Capable: The unit allows you to play independent sources simultaneously in the front and rear zones. There are two composite video outputs plus RCA stereo audio to feed the rear zone. Rear View Camera Input: The head unit features a function that automatically switches to the image from a rearview camera (if installed) when you shift into reverse. You can display it as normal or a mirror image. Navigation Ready: An optional navigation unit, the NAV101 (item number 110NAV101), can be added to the VM9022. Source Volume: The relative volume of each input can be set such that changing from one to another doesn't result in a large change in volume. Anti-Theft Code: When the VM9022 is first powered up after being connected to a power source, a password screen is displayed requiring input of the six digit security code. The initial code, listed in the manual, is input during installation. Once the installation is complete, change the code in the setup menu. Beep Tones: An audible beep tone confirms each function selection. The beep tone can be disabled if you prefer. DVD/CD Features Video Lockout: For safety reasons, you cannot view a video source on the built-in monitor as long as the vehicle is in motion. In order to display video, the supplied pink wire must be hardwired into the vehicle's parking brake light circuit, and the vehicle's parking brake must be engaged. Disc Compatibility: The VM9022 is compatible with the following discs: •DVD: DVD Video, DVD-R, DVD-RW, DVD+R, DVD+RW •VCD: Video CD, Super Video CD •CD: Audio CD (CD-DA), CD-R, CD-RW •Other Compatible Formats: MP3, WMA, JPEG, AVI, XviD, and DivX Note: 8 cm discs should not be used in this unit. Surround Channels: You can switch between 4.0 (2-channel stereo), 4.1 (4-channal surround with sub), and 5.1 (surround with sub and canter channel) output modes. Surround Modes: The VM9022 has built-in surround processors for Dolby Digital and Dolby Pro Logic II (music, movie, and matrix modes). Powered Center Channel: There is a speaker level output for a center channel speaker for use with the Dolby Digital or Dolby Pro Logic II surround processors. The output is 22 watts RMS and is CEA-2006 compliant. Dynamic Range Compression: This function reduces a Dolby Digital soundtrack's dynamic range so you can hear quieter dialog without being overwhelmed by loud sections. You can choose a setting of On or Off. Fast Forward/Fast Reverse: When playing a DVD, there are four fast-play speeds in both directions (2x, 4x, 6x, and 8x). Slow Motion: When playing a DVD, there are three slow motion speeds; forward direction only. Repeat Play: When playing a DVD, you can repeat the current chapter or title. When playing a Video CD, you can repeat the current track. For MP3, you can repeat the file or folder. A-B Repeat allows you to repeat any portion of a DVD. Random Play: When playing a DVD, Video CD, or audio CD, you can play the chapters/tracks in random order. Zoom: When playing DVDs, you can enlarge the picture using the zoom feature. Choose one of three zoom settings; 1.5x, 2x, or 3x. Use the joystick control to pan across the enlarged image. Preamp Outputs: If you want 5.1 channel theater-style sound, connect the appropriate external amplifiers and speakers to the front, rear, center, and subwoofer preamp outputs. External Device Controls iPod Control: Using the included MediaLink module and jLink iPod cable you can connect and control your iPod (with dock connector) through the touchscreen display. •Audio And Video Playback: 5th generation iPod video only •Audio Playback Only: iPod mini, iPod nano (1st/2nd/3rd/4th generation), iPod photo, iPod classic and iPod touch (1st/2nd generation) Note: This cable is not compatible with 1st and 2nd generation iPods or shuffle. This cable also will not charge the iPod nano (4th generation) or iPod touch (2nd generation). XM Satellite Radio Ready: The Jensen VM9022 supports XM Radio via the optional CNP2000UC XMdirect2 Tuner (sold separately) and the Jensen CNPJEN1 Connection Cable (package # 700XMJEN1). In addition, you will need a subscription to XM Satellite Radio. XM Satellite Radio programming offers 170 digital radio channels including 69 channels of commercial free music, plus news, sports, talk, comedy, and other entertainment programming from coast to coast. XM also offers instant traffic and weather alerts for 21 major US cities, as well as live sports broadcasts from Major League Baseball, NHL, the PGA tour, Indy car racing and several major college conferences. Note: XM Satellite radio service is available only within the continental United States. Service is not available in Alaska and Hawaii. Inputs and Outputs Notes 6-Channel Audio Preamp Outputs: This unit has six audio preamp outputs: front left and right, rear left and right, center, and subwoofer. Multi Zone Output: The Multi Zone output consists of left and right RCA audio jacks and two RCA composite video jacks, allowing you to connect optional back seat monitors and a headphone system. Aux Inputs: There are two auxiliary A/V inputs, consisting of left and right RCA audio jacks and an RCA composite video jack, allowing you to connect external equipment to this head unit. Aux 1 is typically used for the MultiLink module. Camera Input: This RCA composite video jack allows you connect an optional rear view camera. Pret de nou: 800 euro Pret VANZARE: 1400 ron neg 0729 125 357 0765 917 047 http://i48.tinypic.com/2hnrlfk.jpg http://i45.tinypic.com/6pc74l.jpg http://i46.tinypic.com/14n0o6u.jpg http://i49.tinypic.com/scuirq.jpg |
Re: VAND DVD NOU NAVI Bluetooth, TOUCH, full conectivity la cutie, cu accesorii
1200 ron doar saptamana asta
1100ron banu jos sau 1400 în combinaţii cu statii, baterii deep, cabluri, cd-playere cu 6 rca, boxe uşi, tweetere, etc
1100 sapt asta sau pleaca pe eBay.
Hai cu propuneri,combinatii :D |
| All times are GMT +2. The time now is 04:46. |
