vand amp db master 3000w
1. Amplificator Db master sra 4800d 1ooo lei
tel 0760318152 Stiind ca numai un nebun cu muzica ar putea sa-si achizitioneze asa ceva, am cautat pe net si am strans cateva linkuri cu review-uri, pareri, forumuri, preturi pe care le postez la sfarsitul fiecarei descrieri a produsului 1. Specificatii Amplificator Db master sra 4800 : Sigma-delta Platform Through Hole Technology Double sided Epoxy Military Standard PCB Center Path Technology(Patent Pending ) regulated Power Supply "Full Mosfet" Power Supply&Output Stages Dual 0 Gage Power Inputs Dual 0 Gage Ground Inputs 0.5 Ohm Stable 14.4V Input Voltage Output Power: Class-D Technology(Mono) 1 x 800 Watts Rms @ 4 Ohms (Currunt Draw 60A) 1 x 1500 Watts Rms @ 2 Ohms (Currunt Draw 130A) 1 x 2800 Watts Rms @ 1 Ohms (Currunt Draw 240A) sra4800.dlinked into 4Ohm x 1Channel Delivers a Blistering 3200(RMS) Watts sra4800.dlinked into 2Ohm x 1Channel Delivers a Blistering 6400(RMS) Watts and Some change! Frequency Response: 20Hz-330Hz Singnal to Noise Ratio(S/N): >90dB Total Harmonic Distortion(THD): <0>700 Minimum Load Stability For all Channels: 0.5Ohms Surse : http://www.bmssound.com/popup_image....oothfdr4l52e90 https://forum.4tuning.ro/554-amplific...ra-4800-a.html http://quezoncity.olx.com.ph/for-spl...k-iid-40154850[/QUOTE] |
| All times are GMT +2. The time now is 18:30. |
