Amplificator Dls Monoblock D1000
mplificator DLS mono D1000
RMS output per channel at 13,5 volts Power output in 4 ohm (0,3% THD) : 350 Watts Power output in 2 ohm (0,5% THD) : 700 Watts Power output in 1 ohm (1 % THD) : 1000 Watts Frequency range : 15 Hz - 160 Hz S / N-ratio, A-weighted : > 80 dB Damping factor 4 ohm 100 Hz : > 300 Input impedance : 22 kohm Input sensitivity, variable : 0,2 - 6 V Bass bost : 0- +18 dB Lowpass crossover : LP: 35 - 250 Hz Subsonic filter : 15 - 35 Hz Power consumption, idle : 0,9 A Maximum power consumption : 97 A Dimensions H x W x D : 65 x 407 x 240 mm Weight : 5,4 kg Pret: 750 LEI Stare impecabila ... nu cred ca are rost sa mai dau detalii despre amp .. :twisted: |
Re: Amplificator Dls Monoblock D1000
valabil ...
disponibil ...
700 ron
650 ron ...:???:
SChimb+dif cu dls ca31,sau cu ground zero 1.800mk2 ?
nu ms
valabil
valabil..
700 ron ... disponibil!
650 ron fix!!
schimb cu amp de 1600-2500w la 1 ohm ofer dif ...
https://www.youtube.com/watch?v=-4X-2ovbD9A |
disponibil amp foarte potent!!
valabil...
Cat oferi la un GZNA 1.2500 ?
| All times are GMT +2. The time now is 13:07. |
