-   Drift Section - Sideways Action (https://forum.4tuning.ro/361-drift-section-sideways-action.html)
-   -   Introducing DRIFT - Slide with Style (https://forum.4tuning.ro/361-drift-section-sideways-action/34759-introducing-drift-slide-with-style.html)
CJ-01-WOB 03-03-07 00:17
''Drifting refers either to a driving technique, or to a sport based on the technique; this article deals primarily with the sport. When the rear slip angle is greater than the front slip angle, and the front wheels are pointed in the opposite direction to the turn (e.g. car is turning left, wheels are pointed right), and the driver is controlling this, the car is drifting.''
Definitaia generala a driftului
, si anume e caracterizat ca fiind o tehnica de condus
Cand unghiul de alunecare al rotilor din spate este mai mare decat unghiul de alunecare al rotilor din fata, iar rotile din fata sunt virate in directia opusa curbei si pilotul are controlul masinii!
CJ-01-WOB 11-03-07 02:39
Re: Introducing DRIFT - Slide with Style
DE CE DRIFT ?
Simplu!
Urmareste filmuletul de mai jos si infecteaza-te cu virusul care deja face ravagii in toata lumea ! Observa cat de mult FUN pot sa aiba personajele din prezentare!
<embed src="http://www.metacafe.com/fplayer/123239/real_life.swf" width="400" height="345" wmode="transparent" pluginspage="http://www.macromedia.com/go/getflashplayer" type="application/x-shockwave-flash"></embed><br><font size = 1><a href="http://www.metacafe.com/watch/123239/real_life/"></a> - <a href='http:///'></a></font>
CJ-01-WOB 31-03-07 03:34
Drift - a driving movement of force
Drifting refers either to a driving technique utilizing a difference in slip angle between the front and rear tires of a car, or to a sport based on the technique; this article deals primarily with the sport. When the rear wheels are slipping at a greater angle than the front wheels, the car is drifting, or "power-sliding". The rear end of the car appears to chase the front end around a turn; the driver utilizes both front tires and the rear tires to control the actual direction of the car. More throttle induces more rear wheel slip angle and the rear of the car wants to overtake the front. The goal is for the driver to achieve opposite lock and use the throttle to fine tune the car's angle and direction.
Sollo 27-04-07 17:20
[QUOTE=CJ-01-WOB;826086]Drift - a driving movement of force
driftul e cel mai tare mod de a-ti creste nivelul de adrenalina
Ionut90 01-05-07 21:16
:)) poate ai dreptate dar nu uita ca mai sunt si alte metode de a-ti creste nivelul de adrenalina :P
Xerius 08-07-07 02:54
super tarde filmul, din pacate sunt prea putini romani care fac intr-adevar drift. Marea majoritate fac cerculete si se cred drift-eri
AdiNX 15-07-07 18:54
cat curaj pe japonezii astia... highspeed drifting in the middle of the night ;)
MARI_NSL 16-07-07 00:37
ce grav se dadeau , nb aia .:)) frumos , cand o fi si pe la noi asa ceva :d
Ali_ump 16-07-07 19:30
It's starting...already
gavrila 22-07-07 00:16
normal ca stia traseul...da ceterinca...
DrifTinG 31-07-07 12:28
Chiar daca stii traseul tot e periculos...la noi vezi mai rar asa ceva....aproape deloc:D
Keisuke 31-07-07 12:52
Originally Posted by CJ-01-WOB (Post 791563)
DE CE DRIFT ?
Simplu!
Ce volan tare are :lol: :lol: :lol:
Xerius 31-07-07 15:02
oare de ce cand ai nostri romani cand vad un adevarat drift spun ca este nebunie ?? KAMIKAZE domne !!!
ala e drift adevarat... nu e nebunie... se numeste drift.. alunecare controlata
DrifTinG 31-07-07 15:04
corect:)) romanii se uita la driftingul din alta parte k la masini straine:)))))
AdiNX 31-07-07 15:32
nu e vorba de asta, ci de pericolul la care se expun soferii daca fac drifting pe intuneric.. intr-adevar, dupa ce ai facut asta ani de zile si cunosti traseul nu crezi ca e posibil sa fie vreo problema daca faci asta si pe intuneric, dar daca e ceva/cineva pe care nu reusesti sa vezi din timp si faci poc?
btw.. stie cineva cand se mai da drifting pe motors tv? am observat ca nu mai figureaza in program :(
